Problem with wall thickness in single outline mode (spiral v
Posted: Sat Apr 16, 2016 9:56 pm
I like printing my rockets in spiral vase mode. not only is it much faster but its actually usable. nice flexible strong parts.
well today I am having a headache. I have a rocket I am printing off thingiverse.
I had to seperate and resolid it in 3d to get it proper but thats fine got a good outline tool path now for single outline mode.
SO
I enlarge the rocket 3 times my print bed height. and I print it in 3 pieces.
the bottom prints perfectly. the top prints "ok" the middle is so brittle and thin its unusable.
I change NOTHING in settings and since I am printing spiral vase mode it should not matter what portion of the model I am printing all walls should be the same since no settings are changing. but the middle is so weak its hard to even get it out of the printer without it coming apart in my fingers.
There is a HUGE thickness difference in the walls of the bottom piece and the middle and top piece.
what is changing and how do I stop it? I want it all "thick" like the bottom section.
attached is the factory file. my multiplier is .95 (stock the way simplify set it) in this file its 1.15 (I am trying to up it to see if that gets me thicker walls on the parts that print too thin) I will know in 30 minutes or so.
Here is a video on youtube clearly showing what I am talking about.
https://www.youtube.com/watch?v=FVmNem_5Z3Y
I just took my calipers to the parts and that explains everything but not a solution.
the booster is 1.02mm thick. perfect.
the middle is .48mm thick the top is .54mm thick (so .54mm is borderline I need that thick or thicker less and the part falls apart)
how do I make the walls thicker I assume extrude more plastic??? and why is this extrusion "changing" depending on what part of the rocket I print. in vase mode the part should not matter its single outline. ???
this also explain the part falling apart. not enough plastic is smooshing into the previous layer for a good "melt together" so it delaminates really easy while the 1mm thick part is damned near indestructible (reasonable expected forces)
any help is greatly appreciated.
simplify 3d outputs .factory files and the simplify 3d official forum won't accept .factory files. admins might want to look into that :-)
the attached zip is not a zip rename to .factory
SO
