Fan not starting when told too
Posted: Mon Apr 18, 2016 6:08 pm
by lesdefoor
I am currently using version 3.0 of S3D. I have a brand new Prusa i3 Color directly from Prusa3d.com.
I love using S3D with it over Slic3r. It seems S3D does a better job slicing and printing, with ONE exception, the part fan does NOT come on.
I can issue the Mcode and the fan does come on, but when I create the gcode, the fan does not come on when specified which is the following:
Layer 1 - 0 %
Layer 2 - 100 %
So, the fan should come on when Layer 2 starts and stay on for the rest of the print.
I have an open ticket with S3D, but it seems I am limited to one response per day, so I bet this is going to take a while to get fixed through them. Was wondering if anyone had any other ideas / suggestions to look at?
here is a link to the screen shot of the "Cooling" tab. http://prntscr.com/aty3ev
Re: Fan not starting when told too
Posted: Tue Apr 19, 2016 6:30 am
Can you post your gcode files (one from S3D and the other from your other software). That will make it very easy to compare. You may also want to post your factory file so that others can check your settings (that's much easier than a screenshot ;) ). Just go to File > Save Factory File.
Posted: Tue Apr 19, 2016 8:20 am
by lesdefoor
Absolutely. I will have to try to post them in separate messages as you can only post so much in each of these.
Posted: Tue Apr 19, 2016 8:32 am
by lesdefoor
S3D Code
; G-Code generated by Simplify3D(R) Version 3.0.2
; Apr 19, 2016 at 5:28:00 AM
; Settings Summary
;   processName,Normal Prusa PLA
;   applyToModels,Fan Test
;   profileName,Original Prusa i3 PLA 1.75 NORMAL (modified)
;   profileVersion,2015-12-18 11:49:56
;   baseProfile,Prusa Mendel (modified)
;   printMaterial,PLA
;   printQuality,NORMAL
;   printExtruders,
;   extruderName,Primary Extruder
;   extruderToolheadNumber,0
;   extruderDiameter,0.4
;   extruderAutoWidth,0
;   extruderWidth,0.45
;   extrusionMultiplier,1
;   extruderUseRetract,1
;   extruderRetractionDistance,1.5
;   extruderExtraRestartDistance,0
;   extruderRetractionZLift,0
;   extruderRetractionSpeed,1800
;   extruderUseCoasting,1
;   extruderCoastingDistance,0.2
;   extruderUseWipe,1
;   extruderWipeDistance,2
;   primaryExtruder,0
;   layerHeight,0.2
;   topSolidLayers,3
;   bottomSolidLayers,3
;   perimeterOutlines,2
;   printPerimetersInsideOut,1
;   startPointOption,2
;   startPointOriginX,0
;   startPointOriginY,0
;   startPointOriginZ,300
;   sequentialIslands,0
;   spiralVaseMode,0
;   firstLayerHeightPercentage,100
;   firstLayerWidthPercentage,100
;   firstLayerUnderspeed,0.6
;   useRaft,0
;   raftExtruder,0
;   raftLayers,3
;   raftOffset,3
;   raftSeparationDistance,0.14
;   raftInfill,85
;   disableRaftBaseLayers,0
;   useSkirt,1
;   skirtExtruder,0
;   skirtLayers,1
;   skirtOutlines,1
;   skirtOffset,1.8
;   usePrimePillar,0
;   primePillarExtruder,999
;   primePillarWidth,12
;   primePillarLocation,7
;   primePillarSpeedMultiplier,1
;   useOozeShield,0
;   oozeShieldExtruder,999
;   oozeShieldOffset,2
;   oozeShieldOutlines,1
;   oozeShieldSidewallShape,1
;   oozeShieldSidewallAngle,30
;   oozeShieldSpeedMultiplier,1
;   infillExtruder,0
;   internalInfillPattern,Grid
;   externalInfillPattern,Rectilinear
;   infillPercentage,20
;   outlineOverlapPercentage,21
;   infillExtrusionWidthPercentage,100
;   minInfillLength,2
;   infillLayerInterval,1
;   infillAngles,45,-45
;   overlapInfillAngles,1
;   generateSupport,0
;   supportExtruder,0
;   supportInfillPercentage,30
;   supportExtraInflation,1.4
;   denseSupportLayers,0
;   denseSupportInfillPercentage,70
;   supportLayerInterval,1
;   supportHorizontalPartOffset,0.2
;   supportUpperSeparationLayers,1
;   supportLowerSeparationLayers,1
;   supportType,0
;   supportGridSpacing,4
;   maxOverhangAngle,45
;   supportAngles,0
;   temperatureName,Primary Extruder,Heated Bed
;   temperatureNumber,0,1
;   temperatureSetpointCount,1,1
;   temperatureSetpointLayers,1,1
;   temperatureSetpointTemperatures,210,50
;   temperatureStabilizeAtStartup,1,1
;   temperatureHeatedBed,0,1
;   temperatureRelayBetweenLayers,0,0
;   temperatureRelayBetweenLoops,0,0
;   fanLayers,1,2,3
;   fanSpeeds,0,80,100
;   blipFanToFullPower,1
;   adjustSpeedForCooling,1
;   minSpeedLayerTime,15
;   minCoolingSpeedSlowdown,20
;   increaseFanForCooling,0
;   minFanLayerTime,45
;   maxCoolingFanSpeed,100
;   increaseFanForBridging,1
;   bridgingFanSpeed,100
;   use5D,1
;   relativeEdistances,1
;   allowEaxisZeroing,1
;   independentExtruderAxes,0
;   includeM10123,0
;   stickySupport,1
;   applyToolheadOffsets,0
;   gcodeXoffset,0
;   gcodeYoffset,0
;   gcodeZoffset,0
;   overrideMachineDefinition,1
;   machineTypeOverride,0
;   strokeXoverride,200
;   strokeYoverride,200
;   strokeZoverride,175
;   originOffsetXoverride,0
;   originOffsetYoverride,0
;   originOffsetZoverride,0
;   homeXdirOverride,-1
;   homeYdirOverride,-1
;   homeZdirOverride,-1
;   flipXoverride,1
;   flipYoverride,-1
;   flipZoverride,1
;   toolheadOffsets,0,0|0,0|0,0|0,0|0,0|0,0
;   overrideFirmwareConfiguration,0
;   firmwareTypeOverride,RepRap (Marlin/Repetier/Sprinter)
;   GPXconfigOverride,r2
;   baudRateOverride,250000
;   overridePrinterModels,1
;   printerModelsOverride
;   startingGcode,M201 X1000 Y1000 E600,M92 E161.3,G28,G92 E0.0,G1 X8.0 F2000,G1 Y60.0 E4.0  F1000.0,G1 Y100.0 E8.5  F1000.0,G92 Z0.1,G92 E0.0
;   layerChangeGcode,
;   retractionGcode,
;   toolChangeGcode,
;   endingGcode,M104 S0 ; turn off temperature,M140 S0 ; turn off heatbed,G28 X0  ; home X axis,M84     ; disable motors,M107 ; turn off fan
;   createX3G,0
;   celebration,0
;   celebrationSong,Random Song
;   createMB5G,0
;   postProcessing,
;   defaultSpeed,2400
;   outlineUnderspeed,1
;   solidInfillUnderspeed,1
;   supportUnderspeed,0.8
;   rapidXYspeed,4800
;   rapidZspeed,1000
;   minBridgingArea,50
;   bridgingExtraInflation,1
;   bridgingExtrusionMultiplier,1
;   bridgingSpeedMultiplier,1
;   filamentDiameter,1.75
;   filamentPricePerKg,215
;   filamentDensity,1.25
;   useMinPrintHeight,0
;   minPrintHeight,0
;   useMaxPrintHeight,0
;   maxPrintHeight,0
;   useDiaphragm,0
;   diaphragmLayerInterval,20
;   robustSlicing,1
;   mergeAllIntoSolid,0
;   onlyRetractWhenCrossingOutline,0
;   retractBetweenLayers,1
;   useRetractionMinTravel,1
;   retractionMinTravel,3
;   retractWhileWiping,1
;   onlyWipeOutlines,1
;   avoidCrossingOutline,0
;   maxMovementDetourFactor,3
;   toolChangeRetractionDistance,12
;   toolChangeExtraRestartDistance,-0.5
;   toolChangeRetractionSpeed,600
;   allowThinWallGapFill,1
;   thinWallAllowedOverlapPercentage,10
;   horizontalSizeCompensation,0
G90
M83
M127
M140 S50 T0
M134 T0
M104 S210 T0
M133 T0
M92 E161.3
G28
G92 E0.0
G1 X8.0 F2000
G92 Z0.1
G92 E0.0
G1 E-1.5000 F1800
G1 Z0.200 F1000
; layer 1, Z = 0.2
M135 T0
; tool H0.200 W0.450
; skirt
G1 X95.509 Y96.627 F4800
G1 E1.5000 F540
G1 X96.627 Y95.509 E0.0591 F480
G1 X96.710 Y95.475 E0.0033
G1 X103.290 Y95.475 E0.2462
G1 X103.373 Y95.509 E0.0033
G1 X104.491 Y96.627 E0.0591
G1 X104.525 Y96.710 E0.0033
G1 X104.525 Y103.290 E0.2462
G1 X104.491 Y103.373 E0.0033
G1 X103.373 Y104.491 E0.0591
G1 X103.290 Y104.525 E0.0033
G1 X96.710 Y104.525 E0.2462
G1 X96.627 Y104.491 E0.0033
G1 X95.509 Y103.373 E0.0591
G1 X95.475 Y103.290 E0.0033
G1 X95.475 Y96.820 E0.2421
G1 X95.475 Y96.710 F480
G1 E-1.5000 F1800
; inner perimeter
G1 X98.175 Y98.175 F4800
G1 E1.5000 F1800
G1 X101.825 Y98.175 E0.1366 F480
G1 X101.825 Y101.825 E0.1366
G1 X98.175 Y101.825 E0.1366
G1 X98.175 Y98.375 E0.1291
; outer perimeter
G1 X97.725 Y97.725 F4800
G1 X102.275 Y97.725 E0.1703 F480
G1 X102.275 Y102.275 E0.1703
G1 X97.725 Y102.275 E0.1703
G1 X97.725 Y97.925 E0.1628
G1 X99.725 Y97.725 F2400
; solid layer
G1 X98.531 Y98.924 F4800
G1 X98.924 Y98.531 E0.0208 F480
G1 X99.560 Y98.531 E0.0238
G1 X98.531 Y99.560 E0.0545
G1 X98.531 Y100.197 E0.0238
G1 X100.197 Y98.531 E0.0882
G1 X100.833 Y98.531 E0.0238
G1 X98.531 Y100.833 E0.1218
G1 X98.531 Y101.469 E0.0238
G1 X98.531 Y101.469 E0.0000
G1 X101.469 Y98.531 E0.1555
G1 X101.469 Y99.167 E0.0238
G1 X99.167 Y101.469 E0.1218
G1 X99.803 Y101.469 E0.0238
G1 X101.469 Y99.803 E0.0882
G1 X101.469 Y100.440 E0.0238
G1 X100.440 Y101.469 E0.0545
G1 X101.076 Y101.469 E0.0238
G1 X101.328 Y101.218 E0.0133
G1 X101.469 Y101.076 F480
G1 E-1.5000 F1800
; layer 2, Z = 0.4
M126 S204
; inner perimeter
G1 X101.825 Y101.825 F4800
G1 Z0.400 F1000
G1 E1.5000 F1800
G1 X98.175 Y101.825 E0.1366 F480
G1 X98.175 Y98.175 E0.1366
G1 X101.825 Y101.625 E0.1291
; outer perimeter
G1 X102.275 Y102.275 F4800
G1 X97.725 Y102.275 E0.1703 F480
G1 X97.725 Y97.725 E0.1703
G1 X102.275 Y102.075 E0.1628
G1 X100.275 Y102.275 F2400
; solid layer
G1 X98.924 Y101.469 F4800
G1 X98.531 Y101.076 E0.0208 F480
G1 X98.531 Y100.440 E0.0238
G1 X99.560 Y101.469 E0.0545
G1 X100.197 Y101.469 E0.0238
G1 X98.531 Y99.803 E0.0882
G1 X98.531 Y99.167 E0.0238
G1 X100.833 Y101.469 E0.1218
G1 X101.469 Y101.469 E0.0238
G1 X101.469 Y101.469 E0.0000
G1 X98.531 Y98.531 E0.1555
G1 X99.167 Y98.531 E0.0238
G1 X101.469 Y100.833 E0.1218
G1 X101.469 Y100.197 E0.0238
G1 X99.803 Y98.531 E0.0882
G1 X100.440 Y98.531 E0.0238
G1 X101.469 Y99.560 E0.0545
G1 X101.469 Y98.924 E0.0238
G1 X101.218 Y98.672 E0.0133
G1 X101.076 Y98.531 F480
G1 E-1.5000 F1800
; layer 3, Z = 0.6
M126 S255
; inner perimeter
G1 X101.825 Y98.175 F4800
G1 Z0.600 F1000
G1 E1.5000 F1800
G1 X101.825 Y101.825 E0.1366 F480
G1 X101.625 Y98.175 E0.1291
; outer perimeter
G1 X102.275 Y97.725 F4800
G1 X102.275 Y102.275 E0.1703 F480
G1 X102.075 Y97.725 E0.1628
G1 X102.275 Y99.725 F2400
; solid layer
G1 X101.469 Y101.076 F4800
G1 X101.076 Y101.469 E0.0208 F480
G1 X100.440 Y101.469 E0.0238
G1 X101.469 Y100.440 E0.0545
G1 X101.469 Y99.803 E0.0238
G1 X99.803 Y101.469 E0.0882
G1 X99.167 Y101.469 E0.0238
G1 X101.469 Y99.167 E0.1218
G1 X101.469 Y98.531 E0.0238
G1 X98.531 Y101.469 E0.1555
G1 X98.531 Y100.833 E0.0238
G1 X100.833 Y98.531 E0.1218
G1 X100.197 Y98.531 E0.0238
G1 X98.531 Y100.197 E0.0882
G1 X98.531 Y99.560 E0.0238
G1 X99.560 Y98.531 E0.0545
G1 X98.924 Y98.531 E0.0238
G1 X98.672 Y98.783 E0.0133
G1 E-1.5000 F1800
; layer 4, Z = 0.8
; inner perimeter
G1 Z0.800 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 X98.531 Y98.531 F4800
G1 X101.328 Y101.328 E0.1480 F480
G1 X101.469 Y101.469 F480
G1 X101.469 Y98.531 F4800
G1 X98.672 Y101.328 E0.1480 F480
G1 X98.531 Y101.469 F480
G1 E-1.5000 F1800
; layer 5, Z = 1
; inner perimeter
G1 X98.175 Y101.825 F4800
G1 Z1.000 F1000
G1 E1.5000 F1800
G1 X98.175 Y98.175 E0.1366 F480
G1 X98.375 Y101.825 E0.1291
; outer perimeter
G1 X97.725 Y102.275 F4800
G1 X97.725 Y97.725 E0.1703 F480
G1 X97.925 Y102.275 E0.1628
G1 X97.725 Y100.275 F2400
; infill
G1 X98.531 Y101.469 F4800
G1 X101.328 Y98.672 E0.1480 F480
G1 X101.469 Y101.469 F4800
G1 X98.672 Y98.672 E0.1480 F480
G1 E-1.5000 F1800
; layer 6, Z = 1.2
; inner perimeter
G1 Z1.200 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 E-1.5000 F1800
; layer 7, Z = 1.4
; inner perimeter
G1 Z1.400 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 E-1.5000 F1800
; layer 8, Z = 1.6
; inner perimeter
G1 Z1.600 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 E-1.5000 F1800
; layer 9, Z = 1.8
; inner perimeter
G1 Z1.800 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 E-1.5000 F1800
; layer 10, Z = 2
; inner perimeter
G1 Z2.000 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 E-1.5000 F1800
; layer 11, Z = 2.2
; inner perimeter
G1 Z2.200 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 E-1.5000 F1800
; layer 12, Z = 2.4
; inner perimeter
G1 Z2.400 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 E-1.5000 F1800
; layer 13, Z = 2.6
; inner perimeter
G1 Z2.600 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 E-1.5000 F1800
; layer 14, Z = 2.8
; inner perimeter
G1 Z2.800 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 E-1.5000 F1800
; layer 15, Z = 3
; inner perimeter
G1 Z3.000 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 E-1.5000 F1800
; layer 16, Z = 3.2
; inner perimeter
G1 Z3.200 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 E-1.5000 F1800
; layer 17, Z = 3.4
; inner perimeter
G1 Z3.400 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 E-1.5000 F1800
; layer 18, Z = 3.6
; inner perimeter
G1 Z3.600 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 E-1.5000 F1800
; layer 19, Z = 3.8
; inner perimeter
G1 Z3.800 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 E-1.5000 F1800
; layer 20, Z = 4
; inner perimeter
G1 Z4.000 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 E-1.5000 F1800
; layer 21, Z = 4.2
; inner perimeter
G1 Z4.200 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 E-1.5000 F1800
; layer 22, Z = 4.4
; inner perimeter
G1 Z4.400 F1000
G1 E1.5000 F1800
; outer perimeter
; infill
G1 E-1.5000 F1800
; layer 23, Z = 4.6
; inner perimeter
G1 Z4.600 F1000
G1 E1.5000 F1800
; outer perimeter
; solid layer
G1 E-1.5000 F1800
; layer 24, Z = 4.8
; inner perimeter
G1 Z4.800 F1000
G1 E1.5000 F1800
; outer perimeter
; solid layer
G1 E-1.5000 F1800
; layer 25, Z = 5
; inner perimeter
G1 Z5.000 F1000
G1 E1.5000 F1800
; outer perimeter
; solid layer
G1 E-1.5000 F1800
; layer end
M107 ; turn off fan
; Build Summary
;   Build time: 0 hours 2 minutes
;   Filament length: 42.6 mm (0.04 m)
;   Plastic volume: 102.54 mm^3 (0.10 cc)
;   Plastic weight: 0.13 g (0.00 lb)
;   Material cost: 0.03
Posted: Tue Apr 19, 2016 8:35 am
by lesdefoor
Slic3r Code - I had to remove a few lines off the bottom of the code to get it to fit in here.
; generated by Slic3r 1.2.9 on 2016-04-19 at 05:29:39
; external perimeters extrusion width = 0.30mm
; perimeters extrusion width = 0.30mm
; infill extrusion width = 0.50mm
; solid infill extrusion width = 0.30mm
; top infill extrusion width = 0.30mm
M107
M190 S50 ; set bed temperature
M109 S215
M92 E161.3
G28
G92 E0.0
G1 X8.0 F2000
G92 E0.0
G21 ; set units to millimeters
G90 ; use absolute coordinates
M83 ; use relative distances for extrusion
G1 E-1.50000 F1800.00000
G1 Z0.150 F6000.000
G1 X92.100 Y93.136 F6000.000
G1 E1.50000 F1800.00000
G1 E0.03287 F1800.000 ; pressure advance
G1 X93.864 Y91.585 E0.08538 F1599.682
G1 X96.043 Y90.711 E0.08538
G1 X97.500 Y90.557 E0.05327
G1 X102.500 Y90.557 E0.18180
G1 X104.815 Y90.954 E0.08538
G1 X106.865 Y92.100 E0.08538
G1 X108.415 Y93.863 E0.08538
G1 X109.289 Y96.043 E0.08538
G1 X109.444 Y97.500 E0.05327
G1 X109.444 Y102.500 E0.18180
G1 X109.047 Y104.815 E0.08538
G1 X107.901 Y106.864 E0.08538
G1 X106.137 Y108.415 E0.08538
G1 X103.957 Y109.289 E0.08538
G1 X102.500 Y109.444 E0.05327
G1 X97.500 Y109.444 E0.18180
G1 X95.186 Y109.046 E0.08538
G1 X93.136 Y107.901 E0.08538
G1 X91.585 Y106.137 E0.08538
G1 X90.711 Y103.957 E0.08538
G1 X90.557 Y102.500 E0.05327
G1 X90.557 Y97.500 E0.18180
G1 X90.954 Y95.186 E0.08538
G1 X92.071 Y93.188 E0.08320
G1 X92.742 Y93.378 F6000.000
G1 X94.482 Y91.975 E0.08127 F1599.682
G1 X97.500 Y91.205 E0.11325
G1 X102.500 Y91.205 E0.18180
G1 X104.700 Y91.601 E0.08127
G1 X106.622 Y92.742 E0.08127
G1 X108.025 Y94.482 E0.08127
G1 X108.796 Y97.500 E0.11325
G1 X108.796 Y102.500 E0.18180
G1 X108.399 Y104.700 E0.08127
G1 X107.259 Y106.622 E0.08127
G1 X105.518 Y108.025 E0.08127
G1 X102.500 Y108.796 E0.11325
G1 X97.500 Y108.796 E0.18180
G1 X95.300 Y108.399 E0.08127
G1 X93.378 Y107.259 E0.08127
G1 X91.975 Y105.518 E0.08127
G1 X91.205 Y102.500 E0.11325
G1 X91.205 Y97.500 E0.18180
G1 X91.601 Y95.300 E0.08127
G1 X92.711 Y93.430 E0.07909
G1 X93.383 Y93.635 F6000.000
G1 X95.094 Y92.390 E0.07694 F1599.682
G1 X97.500 Y91.852 E0.08963
G1 X102.500 Y91.852 E0.18180
G1 X104.579 Y92.249 E0.07694
G1 X106.366 Y93.383 E0.07694
G1 X107.610 Y95.094 E0.07694
G1 X108.148 Y97.500 E0.08964
G1 X108.148 Y102.500 E0.18180
G1 X107.752 Y104.579 E0.07694
G1 X106.618 Y106.366 E0.07694
G1 X104.906 Y107.610 E0.07694
G1 X102.500 Y108.148 E0.08964
G1 X97.500 Y108.148 E0.18180
G1 X95.421 Y107.752 E0.07694
G1 X93.635 Y106.618 E0.07694
G1 X92.390 Y104.906 E0.07694
G1 X91.852 Y102.500 E0.08963
G1 X91.852 Y97.500 E0.18180
G1 X92.249 Y95.421 E0.07694
G1 X93.350 Y93.685 E0.07476
G1 E-0.03287 F1800.000 ; pressure discharge
G1 X101.815 Y101.815 F6000.000
G1 E0.00051 F1800.000 ; pressure advance
G1 X98.186 Y101.815 E0.05454 F479.905
G1 X98.186 Y98.186 E0.05454
G1 X101.815 Y98.186 E0.05454
G1 X101.815 Y101.755 E0.05364
G1 X102.082 Y102.082 F6000.000
G1 X97.918 Y102.082 E0.06260 F479.905
G1 X97.918 Y97.918 E0.06260
G1 X102.082 Y97.918 E0.06260
G1 X102.082 Y102.022 E0.06169
G1 X102.350 Y102.350 F6000.000
G1 X97.650 Y102.350 E0.07065 F479.905
G1 X97.650 Y97.650 E0.07065
G1 X102.350 Y97.650 E0.07065
G1 X102.350 Y102.290 E0.06974
G1 X102.004 Y102.150 F6000.000
G1 E-0.00051 F1800.000 ; pressure discharge
G1 X101.629 Y98.525 F6000.000
G1 E0.00377 F1800.000 ; pressure advance
G1 X101.475 Y98.371 E0.00335 F1279.746
G1 X101.087 Y98.371 E0.00597
G1 X101.629 Y98.913 E0.01179
G1 X101.629 Y99.301 E0.00597
G1 X100.699 Y98.371 E0.02024
G1 X100.311 Y98.371 E0.00597
G1 X101.629 Y99.689 E0.02869
G1 X101.629 Y100.077 E0.00597
G1 X99.923 Y98.371 E0.03714
G1 X99.535 Y98.371 E0.00597
G1 X101.629 Y100.465 E0.04559
G1 X101.629 Y100.853 E0.00597
G1 X99.147 Y98.371 E0.05404
G1 X98.759 Y98.371 E0.00597
G1 X101.629 Y101.241 E0.06249
G1 X101.609 Y101.609 E0.00567
G1 X98.391 Y98.391 E0.07007
G1 X98.371 Y98.759 E0.00567
G1 X101.241 Y101.629 E0.06249
G1 X100.853 Y101.629 E0.00597
G1 X98.371 Y99.147 E0.05404
G1 X98.371 Y99.535 E0.00597
G1 X100.465 Y101.629 E0.04559
G1 X100.077 Y101.629 E0.00597
G1 X98.371 Y99.923 E0.03714
G1 X98.371 Y100.311 E0.00597
G1 X99.689 Y101.629 E0.02869
G1 X99.301 Y101.629 E0.00597
G1 X98.371 Y100.699 E0.02024
G1 X98.371 Y101.087 E0.00597
G1 X98.913 Y101.629 E0.01179
G1 X98.525 Y101.629 E0.00597
G1 X98.371 Y101.475 E0.00334
M104 S210 ; set temperature
G1 E-0.00377 F1800.000 ; pressure discharge
G1 Z0.250 F6000.000
G1 X101.793 Y101.793 F6000.000
G1 E0.00010 F1800.000 ; pressure advance
G1 X98.207 Y101.793 E0.03737 F300.000
G1 X98.207 Y98.207 E0.03737
G1 X101.793 Y98.207 E0.03737
G1 X101.793 Y101.733 E0.03675
G1 X102.072 Y102.072 F6000.000
G1 X97.929 Y102.072 E0.04318 F300.000
G1 X97.929 Y97.929 E0.04318
G1 X102.072 Y97.929 E0.04318
G1 X102.072 Y102.012 E0.04255
G1 X97.650 Y102.350 E0.04898 F300.000
G1 X97.650 Y97.650 E0.04898
G1 X102.350 Y97.650 E0.04898
G1 X102.350 Y102.290 E0.04836
G1 E-0.00010 F1800.000 ; pressure discharge
G1 X101.441 Y101.599 F6000.000
G1 E0.00054 F1800.000 ; pressure advance
G1 X101.599 Y101.441 E0.00240 F694.935
G1 X101.599 Y101.036 E0.00435
G1 X101.036 Y101.599 E0.00855
G1 X100.630 Y101.599 E0.00435
G1 X101.599 Y100.630 E0.01469
G1 X101.599 Y100.225 E0.00435
G1 X100.225 Y101.599 E0.02084
G1 X99.820 Y101.599 E0.00435
G1 X101.599 Y99.820 E0.02699
G1 X101.599 Y99.414 E0.00435
G1 X99.414 Y101.599 E0.03314
G1 X99.009 Y101.599 E0.00435
G1 X101.599 Y99.009 E0.03928
G1 X101.599 Y98.604 E0.00435
G1 X98.604 Y101.599 E0.04543
G1 X98.401 Y101.397 E0.00307
G1 X101.397 Y98.401 E0.04543
G1 X100.991 Y98.401 E0.00435
G1 X98.401 Y100.991 E0.03928
G1 X98.401 Y100.586 E0.00435
G1 X100.586 Y98.401 E0.03314
G1 X100.181 Y98.401 E0.00435
G1 X98.401 Y100.181 E0.02699
G1 X98.401 Y99.775 E0.00435
G1 X99.775 Y98.401 E0.02084
G1 X99.370 Y98.401 E0.00435
G1 X98.401 Y99.370 E0.01469
G1 X98.401 Y98.965 E0.00435
G1 X98.965 Y98.401 E0.00855
G1 X98.559 Y98.401 E0.00435
G1 X98.401 Y98.559 E0.00240
G1 E-0.00054 F1800.000 ; pressure discharge
G1 Z0.350 F6000.000
G1 X101.599 Y98.559 F6000.000
G1 X101.441 Y98.401 E0.00240 F694.935
G1 X101.036 Y98.401 E0.00435
G1 X101.599 Y98.965 E0.00855
G1 X101.599 Y99.370 E0.00435
G1 X100.630 Y98.401 E0.01469
G1 X100.225 Y98.401 E0.00435
G1 X101.599 Y99.775 E0.02084
G1 X101.599 Y100.181 E0.00435
G1 X99.820 Y98.401 E0.02699
G1 X99.414 Y98.401 E0.00435
G1 X101.599 Y100.586 E0.03314
G1 X101.599 Y100.991 E0.00435
G1 X99.009 Y98.401 E0.03928
G1 X98.604 Y98.401 E0.00435
G1 X101.599 Y101.397 E0.04543
G1 X101.397 Y101.599 E0.00307
G1 X98.401 Y98.604 E0.04543
G1 X98.401 Y99.009 E0.00435
G1 X100.991 Y101.599 E0.03928
G1 X100.586 Y101.599 E0.00435
G1 X98.401 Y99.414 E0.03314
G1 X98.401 Y99.820 E0.00435
G1 X100.181 Y101.599 E0.02699
G1 X99.775 Y101.599 E0.00435
G1 X98.401 Y100.225 E0.02084
G1 X98.401 Y100.630 E0.00435
G1 X99.370 Y101.599 E0.01469
G1 X98.965 Y101.599 E0.00435
G1 X98.401 Y101.036 E0.00855
G1 X98.401 Y101.441 E0.00435
G1 X98.559 Y101.599 E0.00240
M106 S204
G1 Z0.450 F6000.000
G1 Z0.550 F6000.000
G1 Z0.650 F6000.000
G1 Z0.750 F6000.000
G1 Z0.850 F6000.000
G1 Z0.950 F6000.000
G1 X100.492 Y101.542 F6000.000
G1 E0.00210 F1800.000 ; pressure advance
G1 X98.459 Y99.509 E0.05148 F819.974
G1 X100.116 Y98.459 E0.03513
G1 X101.542 Y99.885 E0.03611
G1 E-0.00210 F1800.000 ; pressure discharge
G1 Z1.050 F6000.000
G1 X100.116 Y101.542 F6000.000
G1 X101.542 Y100.116 E0.03611 F819.974
G1 X100.492 Y98.459 E0.03513
G1 X98.459 Y100.492 E0.05148
G1 Z1.150 F6000.000
G1 Z1.250 F6000.000
G1 Z1.350 F6000.000
G1 Z1.450 F6000.000
G1 Z1.550 F6000.000
G1 Z1.650 F6000.000
G1 Z1.750 F6000.000
G1 Z1.850 F6000.000
G1 Z1.950 F6000.000
G1 Z2.050 F6000.000
G1 Z2.150 F6000.000
G1 Z2.250 F6000.000
G1 Z2.350 F6000.000
G1 Z2.450 F6000.000
G1 Z2.550 F6000.000
G1 Z2.650 F6000.000
G1 Z2.750 F6000.000
G1 Z2.850 F6000.000
G1 Z2.950 F6000.000
G1 Z3.050 F6000.000
G1 Z3.150 F6000.000
G1 Z3.250 F6000.000
G1 Z3.350 F6000.000
G1 Z3.450 F6000.000
G1 Z3.550 F6000.000
G1 Z3.650 F6000.000
G1 Z3.750 F6000.000
G1 Z3.850 F6000.000
G1 Z3.950 F6000.000
G1 Z4.050 F6000.000
G1 Z4.150 F6000.000
G1 Z4.250 F6000.000
G1 E0.00013 F1800.000 ; pressure advance
G1 X98.207 Y101.793 E0.03737 F356.272
G1 X97.929 Y102.072 E0.04318 F356.272
G1 X97.650 Y102.350 E0.04898 F356.272
G1 E-0.00013 F1800.000 ; pressure discharge
G1 X101.514 Y101.629 F6000.000
M106 S204
G1 E0.00050 F1800.000 ; pressure advance
G1 X101.629 Y101.514 E0.00078 F1500.000
G1 X101.629 Y101.262 E0.00121
G1 X101.262 Y101.629 E0.00248
G1 X101.011 Y101.629 E0.00121
G1 X101.629 Y101.011 E0.00419
G1 X101.629 Y100.760 E0.00121
G1 X100.760 Y101.629 E0.00589
G1 X100.508 Y101.629 E0.00121
G1 X101.629 Y100.508 E0.00760
G1 X101.629 Y100.257 E0.00121
G1 X100.257 Y101.629 E0.00930
G1 X100.006 Y101.629 E0.00121
G1 X101.629 Y100.006 E0.01101
G1 X101.629 Y99.754 E0.00121
G1 X99.754 Y101.629 E0.01271
G1 X99.503 Y101.629 E0.00121
G1 X101.629 Y99.503 E0.01442
G1 X101.629 Y99.252 E0.00121
G1 X99.252 Y101.629 E0.01612
G1 X99.000 Y101.629 E0.00121
G1 X101.629 Y99.000 E0.01782
G1 X101.629 Y98.749 E0.00121
G1 X98.749 Y101.629 E0.01953
G1 X98.497 Y101.629 E0.00121
G1 X101.629 Y98.497 E0.02123
G1 X101.503 Y98.372 E0.00085
G1 X98.372 Y101.503 E0.02123
G1 X98.372 Y101.252 E0.00121
G1 X101.252 Y98.372 E0.01953
G1 X101.000 Y98.372 E0.00121
M107
; filament used = 44.3mm (0.1cm3)
; avoid_crossing_perimeters = 0
; bed_shape = 200.01x-0.00091,200.012x0.005409,200.01x0.006186,200.01x199.994,200.012x199.995,200.01x200.001,200.011x200.017,200.01x200.016,199.998x200.01,199.991x200.01,199.99x200.01,189.99x200.01,189.99x195.01,170.01x195.01,170.01x199.99,170.01x199.99,170.01x200,170.01x200.01,170x200.01,29.99x200.01,29.99x195.01,10.01x195.01,10.01x200.01,0.009509x200.01,0.009496x200.01,0.002241x200.01,-0.010875x200.017,-0.010069x200.001,-0.011561x199.995,-0.01001x199.994,-0.01001x0.006186,-0.011561x0.005409,-0.010069x-0.00091,-0.010875x-0.016628,0.002241x-0.01007,0.009496x-0.010256,0.009509x-0.01001,10.01x-0.01001,10.01x4.98999,29.99x4.98999,29.99x-0.01001,170x-0.01001,170.01x-0.010373,170.01x-8.9e-005,170.01x0.009652,170.01x0.009658,170.01x4.98999,189.99x4.98999,189.99x-0.01001,199.99x-0.01001,199.991x-0.010256,199.998x-0.01007,200.01x-0.016188,200.011x-0.016628
; bed_temperature = 50
; before_layer_gcode =
; bridge_acceleration = 0
; bridge_fan_speed = 80
; brim_width = 0
; complete_objects = 0
; cooling = 1
; default_acceleration = 0
; disable_fan_first_layers = 3
; duplicate_distance = 6
; end_gcode = M104 S0 ; turn off temperature\nM140 S0 ; turn off heatbed\nG28 X0  ; home X axis\nM84     ; disable motors
; extruder_clearance_height = 20
; extruder_clearance_radius = 20
; extruder_offset = 0x0
; extrusion_axis = E
; extrusion_multiplier = 0.9
; fan_always_on = 1
; fan_below_layer_time = 20
; filament_colour = #FFE130
; filament_diameter = 1.75
; first_layer_acceleration = 0
; first_layer_bed_temperature = 50
; first_layer_extrusion_width = 0
; first_layer_speed = 80%
; first_layer_temperature = 215
; gcode_arcs = 0
; gcode_comments = 0
; gcode_flavor = reprap
; infill_acceleration = 0
; infill_first = 0
; layer_gcode =
; max_fan_speed = 80
; max_print_speed = 80
; max_volumetric_speed = 0
; min_fan_speed = 50
; min_print_speed = 5
; min_skirt_length = 4
; notes =
; nozzle_diameter = 0.4
; only_retract_when_crossing_perimeters = 0
; ooze_prevention = 0
; output_filename_format = [input_filename_base].gcode
; perimeter_acceleration = 0
; post_process =
; pressure_advance = 0.035
; resolution = 0
; retract_before_travel = 1
; retract_layer_change = 1
; retract_length = 1.5
; retract_length_toolchange = 3
; retract_lift = 0
; retract_restart_extra = 0
; retract_restart_extra_toolchange = 0
; retract_speed = 30
; skirt_distance = 5
; skirt_height = 1
; skirts = 2
; slowdown_below_layer_time = 15
; spiral_vase = 0
; standby_temperature_delta = -5
; start_gcode = M201 X1000 Y1000 E600\nM109 S[first_layer_temperature]\nM92 E161.3\nG28\nG92 E0.0\nG1 X8.0 F2000\nG1 Y60.0 E4.0  F1000.0\nG1 Y100.0 E8.5  F1000.0\nG92 E0.0
; temperature = 210
; threads = 1
; toolchange_gcode =
; travel_speed = 100
; use_firmware_retraction = 0
; use_relative_e_distances = 1
; use_volumetric_e = 0
; vibration_limit = 0
; wipe = 0
; z_offset = 0
; dont_support_bridges = 1
; extrusion_width = 0.3
; first_layer_height = 0.15
; infill_only_where_needed = 0
; interface_shells = 0
; layer_height = 0.1
; raft_layers = 0
; seam_position = nearest
; support_material = 0
; support_material_angle = 0
; support_material_contact_distance = 0.2
; support_material_enforce_layers = 0
; support_material_extruder = 1
; support_material_extrusion_width = 0.3
; support_material_interface_extruder = 1
; support_material_interface_layers = 3
; support_material_interface_spacing = 0
; support_material_interface_speed = 100%
; support_material_pattern = rectilinear
; support_material_spacing = 1.5
; support_material_speed = 50
; support_material_threshold = 0
; xy_size_compensation = 0
; bottom_solid_layers = 8
; bridge_flow_ratio = 0.1
; bridge_speed = 25
; external_fill_pattern = rectilinear
; external_perimeter_extrusion_width = 0
; external_perimeter_speed = 20
; external_perimeters_first = 0
; extra_perimeters = 0
; fill_angle = 45
; fill_density = 25%
; fill_pattern = rectilinear
; gap_fill_speed = 0
; infill_every_layers = 1
; infill_extruder = 1
; infill_extrusion_width = 0.5
; infill_overlap = 2%
; infill_speed = 60
; overhangs = 0
; perimeter_extruder = 1
; perimeter_extrusion_width = 0
; perimeter_speed = 40
; perimeters = 3
; small_perimeter_speed = 15
; solid_infill_below_area = 0
; solid_infill_every_layers = 0
; solid_infill_extruder = 1
; solid_infill_extrusion_width = 0
; solid_infill_speed = 40
; thin_walls = 0
; top_infill_extrusion_width = 0
; top_solid_infill_speed = 25
; top_solid_layers = 9
Posted: Tue Apr 19, 2016 8:36 am
by lesdefoor
<?xml version="1.0"?>
<profile name="Original Prusa i3 PLA 1.75 NORMAL" version="2015-12-18 11:49:56" app="S3D-Software 3.0.2">
<baseProfile>Prusa Mendel (modified)</baseProfile>
<printMaterial>PLA</printMaterial>
<printQuality>NORMAL</printQuality>
<printExtruders></printExtruders>
<extruder name="Primary Extruder">
<toolheadNumber>0</toolheadNumber>
<diameter>0.4</diameter>
<autoWidth>0</autoWidth>
<width>0.45</width>
<extrusionMultiplier>1</extrusionMultiplier>
<useRetract>1</useRetract>
<retractionDistance>1.5</retractionDistance>
<extraRestartDistance>0</extraRestartDistance>
<retractionZLift>0</retractionZLift>
<retractionSpeed>1800</retractionSpeed>
<useCoasting>1</useCoasting>
<coastingDistance>0.2</coastingDistance>
<useWipe>1</useWipe>
<wipeDistance>2</wipeDistance>
</extruder>
<primaryExtruder>0</primaryExtruder>
<layerHeight>0.2</layerHeight>
<topSolidLayers>3</topSolidLayers>
<bottomSolidLayers>3</bottomSolidLayers>
<perimeterOutlines>2</perimeterOutlines>
<printPerimetersInsideOut>1</printPerimetersInsideOut>
<startPointOption>2</startPointOption>
<startPointOriginX>0</startPointOriginX>
<startPointOriginY>0</startPointOriginY>
<startPointOriginZ>300</startPointOriginZ>
<sequentialIslands>0</sequentialIslands>
<spiralVaseMode>0</spiralVaseMode>
<firstLayerHeightPercentage>100</firstLayerHeightPercentage>
<firstLayerWidthPercentage>100</firstLayerWidthPercentage>
<firstLayerUnderspeed>0.6</firstLayerUnderspeed>
<useRaft>0</useRaft>
<raftExtruder>0</raftExtruder>
<raftLayers>3</raftLayers>
<raftOffset>3</raftOffset>
<raftSeparationDistance>0.14</raftSeparationDistance>
<raftInfill>85</raftInfill>
<disableRaftBaseLayers>0</disableRaftBaseLayers>
<useSkirt>1</useSkirt>
<skirtExtruder>0</skirtExtruder>
<skirtLayers>1</skirtLayers>
<skirtOutlines>1</skirtOutlines>
<skirtOffset>1.8</skirtOffset>
<usePrimePillar>0</usePrimePillar>
<primePillarExtruder>999</primePillarExtruder>
<primePillarWidth>12</primePillarWidth>
<primePillarLocation>7</primePillarLocation>
<primePillarSpeedMultiplier>1</primePillarSpeedMultiplier>
<useOozeShield>0</useOozeShield>
<oozeShieldExtruder>999</oozeShieldExtruder>
<oozeShieldOffset>2</oozeShieldOffset>
<oozeShieldOutlines>1</oozeShieldOutlines>
<oozeShieldSidewallShape>1</oozeShieldSidewallShape>
<oozeShieldSidewallAngle>30</oozeShieldSidewallAngle>
<oozeShieldSpeedMultiplier>1</oozeShieldSpeedMultiplier>
<infillExtruder>0</infillExtruder>
<internalInfillPattern>Grid</internalInfillPattern>
<externalInfillPattern>Rectilinear</externalInfillPattern>
<infillPercentage>20</infillPercentage>
<outlineOverlapPercentage>21</outlineOverlapPercentage>
<infillExtrusionWidthPercentage>100</infillExtrusionWidthPercentage>
<minInfillLength>2</minInfillLength>
<infillLayerInterval>1</infillLayerInterval>
<infillAngles>45,-45</infillAngles>
<overlapInfillAngles>1</overlapInfillAngles>
<generateSupport>0</generateSupport>
<supportExtruder>0</supportExtruder>
<supportInfillPercentage>30</supportInfillPercentage>
<supportExtraInflation>1.4</supportExtraInflation>
<denseSupportLayers>0</denseSupportLayers>
<denseSupportInfillPercentage>70</denseSupportInfillPercentage>
<supportLayerInterval>1</supportLayerInterval>
<supportHorizontalPartOffset>0.2</supportHorizontalPartOffset>
<supportUpperSeparationLayers>1</supportUpperSeparationLayers>
<supportLowerSeparationLayers>1</supportLowerSeparationLayers>
<supportType>0</supportType>
<supportGridSpacing>4</supportGridSpacing>
<maxOverhangAngle>45</maxOverhangAngle>
<supportAngles>0</supportAngles>
<temperatureController name="Primary Extruder">
<temperatureNumber>0</temperatureNumber>
<isHeatedBed>0</isHeatedBed>
<relayBetweenLayers>0</relayBetweenLayers>
<relayBetweenLoops>0</relayBetweenLoops>
<stabilizeAtStartup>1</stabilizeAtStartup>
<setpoint layer="1" temperature="215"/>
</temperatureController>
<temperatureController name="Heated Bed">
<temperatureNumber>1</temperatureNumber>
<isHeatedBed>1</isHeatedBed>
<setpoint layer="1" temperature="50"/>
<fanSpeed>
<setpoint layer="1" speed="0"/>
<setpoint layer="2" speed="100"/>
</fanSpeed>
<blipFanToFullPower>1</blipFanToFullPower>
<adjustSpeedForCooling>1</adjustSpeedForCooling>
<minSpeedLayerTime>15</minSpeedLayerTime>
<minCoolingSpeedSlowdown>20</minCoolingSpeedSlowdown>
<increaseFanForCooling>0</increaseFanForCooling>
<minFanLayerTime>45</minFanLayerTime>
<maxCoolingFanSpeed>100</maxCoolingFanSpeed>
<increaseFanForBridging>1</increaseFanForBridging>
<bridgingFanSpeed>100</bridgingFanSpeed>
<use5D>1</use5D>
<relativeEdistances>1</relativeEdistances>
<allowEaxisZeroing>1</allowEaxisZeroing>
<independentExtruderAxes>0</independentExtruderAxes>
<includeM10123>0</includeM10123>
<stickySupport>1</stickySupport>
<applyToolheadOffsets>0</applyToolheadOffsets>
<gcodeXoffset>0</gcodeXoffset>
<gcodeYoffset>0</gcodeYoffset>
<gcodeZoffset>0</gcodeZoffset>
<overrideMachineDefinition>1</overrideMachineDefinition>
<machineTypeOverride>0</machineTypeOverride>
<strokeXoverride>200</strokeXoverride>
<strokeYoverride>200</strokeYoverride>
<strokeZoverride>175</strokeZoverride>
<originOffsetXoverride>0</originOffsetXoverride>
<originOffsetYoverride>0</originOffsetYoverride>
<originOffsetZoverride>0</originOffsetZoverride>
<homeXdirOverride>-1</homeXdirOverride>
<homeYdirOverride>-1</homeYdirOverride>
<homeZdirOverride>-1</homeZdirOverride>
<flipXoverride>1</flipXoverride>
<flipYoverride>-1</flipYoverride>
<flipZoverride>1</flipZoverride>
<toolheadOffsets>0,0|0,0|0,0|0,0|0,0|0,0</toolheadOffsets>
<overrideFirmwareConfiguration>0</overrideFirmwareConfiguration>
<firmwareTypeOverride>RepRap (Marlin/Repetier/Sprinter)</firmwareTypeOverride>
<GPXconfigOverride>r2</GPXconfigOverride>
<baudRateOverride>250000</baudRateOverride>
<overridePrinterModels>1</overridePrinterModels>
<printerModelsOverride></printerModelsOverride>
<startingGcode>M201 X1000 Y1000 E600,M92 E161.3,G28,G92 E0.0,G1 X8.0 F2000,G1 Y60.0 E4.0 F1000.0,G1 Y100.0 E8.5 F1000.0,G92 Z0.1,G92 E0.0</startingGcode>
<layerChangeGcode></layerChangeGcode>
<retractionGcode></retractionGcode>
<toolChangeGcode></toolChangeGcode>
<endingGcode>M104 S0 ; turn off temperature,M140 S0 ; turn off heatbed,G28 X0 ; home X axis,M84 ; disable motors,M107 ; turn off fan</endingGcode>
<createX3G>0</createX3G>
<celebration>0</celebration>
<celebrationSong>Random Song</celebrationSong>
<createMB5G>0</createMB5G>
<postProcessing></postProcessing>
<defaultSpeed>2400</defaultSpeed>
<outlineUnderspeed>1</outlineUnderspeed>
<solidInfillUnderspeed>1</solidInfillUnderspeed>
<supportUnderspeed>0.8</supportUnderspeed>
<rapidXYspeed>4800</rapidXYspeed>
<rapidZspeed>1000</rapidZspeed>
<minBridgingArea>50</minBridgingArea>
<bridgingExtraInflation>1</bridgingExtraInflation>
<bridgingExtrusionMultiplier>1</bridgingExtrusionMultiplier>
<bridgingSpeedMultiplier>1</bridgingSpeedMultiplier>
<filamentDiameter>1.75</filamentDiameter>
<filamentPricePerKg>215</filamentPricePerKg>
<filamentDensity>1.25</filamentDensity>
<useMinPrintHeight>0</useMinPrintHeight>
<minPrintHeight>0</minPrintHeight>
<useMaxPrintHeight>0</useMaxPrintHeight>
<maxPrintHeight>0</maxPrintHeight>
<useDiaphragm>0</useDiaphragm>
<diaphragmLayerInterval>20</diaphragmLayerInterval>
<robustSlicing>1</robustSlicing>
<mergeAllIntoSolid>0</mergeAllIntoSolid>
<onlyRetractWhenCrossingOutline>0</onlyRetractWhenCrossingOutline>
<retractBetweenLayers>1</retractBetweenLayers>
<useRetractionMinTravel>1</useRetractionMinTravel>
<retractionMinTravel>3</retractionMinTravel>
<retractWhileWiping>1</retractWhileWiping>
<onlyWipeOutlines>1</onlyWipeOutlines>
<avoidCrossingOutline>0</avoidCrossingOutline>
<maxMovementDetourFactor>3</maxMovementDetourFactor>
<toolChangeRetractionDistance>12</toolChangeRetractionDistance>
<toolChangeExtraRestartDistance>-0.5</toolChangeExtraRestartDistance>
<toolChangeRetractionSpeed>600</toolChangeRetractionSpeed>
<allowThinWallGapFill>1</allowThinWallGapFill>
<thinWallAllowedOverlapPercentage>10</thinWallAllowedOverlapPercentage>
<horizontalSizeCompensation>0</horizontalSizeCompensation>
<autoConfigureMaterial name="PLA">
<globalExtruderTemperature>215</globalExtruderTemperature>
<globalBedTemperature>50</globalBedTemperature>
<globalExtrusionMultiplier>1</globalExtrusionMultiplier>
<fanSpeed>
</fanSpeed>
</autoConfigureMaterial>
<autoConfigureQuality name="NORMAL">
</autoConfigureQuality>
</profile>
Posted: Wed Apr 20, 2016 8:24 am
Please post the actual files at attachments and not giant screens of text. Use the "Upload attachment" button when you make a post.
Posted: Thu Apr 21, 2016 1:04 am
by lesdefoor
Hi, thanks for the suggestion of using upload the actual file. Wish I had seen that before hand.
I did want to say, S3D support did find the problem. The software is setting itself to MakerBot/Sailfish Firmware and the Prusa is a RepRap firmware. Once I changed that in the Tools, Configure Firmware option, the fan worked as normal.
The software for some reason, doesn't save this setting for me. I have to keep going back in each time I open the software and change it. But that was the answer. The two firmware's use different M codes to activate the fan.
Posted: Thu Apr 21, 2016 9:34 am
That probably means that you have the firmware override enabled on the G-Code tab of your process settings. That will keep overriding any changes you make in the Tools > Firmware Configuration window anytime you use that process.
They have a nice video explaining all about this here: https://www.youtube.com/watch?v=NYPUAqT4UyI
Posted: Thu Apr 21, 2016 3:38 pm
by lesdefoor
CompoundCarl wrote:That probably means that you have the firmware override enabled on the G-Code tab of your process settings. That will keep overriding any changes you make in the Tools > Firmware Configuration window anytime you use that process.
Nice video? That was an outstanding video and allowed me to understand more about the changes I needed. I have two different printers and now I see why it would default back to the MakerBot. I was even able to configure my own Firmware settings to do a pre-heat and cool down, move to an axis. LOVE it and thank you very much!
