mkjohnson
print preview center/align not same as edit view
I am hoping to get advice on how to modify Simplify3D (profile, settings??) such that when bodies are centered/aligned with Edit-> Center and Arrange, the print preview shows the bodies aligned on the print bed.
I am printing with a MAKEiT-Pro. When I Edit -> Center and Arrange models, the view correctly centers/align as shown in this image:
I expected the bodies to be centered in print preview. They were not. Here is an image:
why doesn't the edit view reflect the print preview view?
Thank you.
Re: print preview center/align not same as edit view
Probably because you have global gcode offsets for your X and Y axes defined in the G-Code tab. Those offsets modify all coordinates in the gcode file (so it will appear shifted).
mkjohnson
That's the problem! The x was offset by 55. Thank you very much.
