Hi All,
This is an interesting problem. Since S3D doesn't allow for changing the speed of small perimeters, I'm forced to set a lower overall speed for the print. I print PETG and can print larger perimeters and objects at 45mm/s. I cut the speed to 20mm/s. I would get skipping or more like pausing on the X and Y motors causing the print to shift after a few layers. At first I thought it might be my Pololu voyage, which I had at .55v and lowered to .45v. I had the same issue. So for comparison, I used the same parameters in Slic3r. I had no skipping or shifting. In both of these scenarios the x/y travel speed was 150mm/s. So I decided to up my speed to 25mm/s in S3D. No more skipping on the X motor. Now when it moved from the outer perimeter to print the inner perimeters, The Y motor made a lockup sound causing the inner perimeters to start in an offset position. So I dropped the x/y travel speed to 120mm/s. I had the same problem but less of a shift. At 100mm/s, still the same problems but even less of a shift. At 80mm/s the problem went away. I have no problem with 150mm/s travel moves in Slic3r prefer the higher speeds to prevent oozing and stringing with S3D. So far the 25mm/s, 80mm/s combo is not shifting where it already would have in the other situations.
What would cause motors to skip in the g code? I was going to attache the gcode files, but they are too big. Is there any other information I can post from the gcode file?
