Walls exactly 3 nozzles thick?
Posted: Sat Apr 23, 2016 6:08 pm
by bryeung
Hello,
The other day I was trying to print more or less a cylinder.
These numbers are all relative to my 0.4mm nozzle size.
Printing it at 0.8mm worked as expected. 2 concentric circles per layer.
Same with printing at 1.6mm. 4 concentric circles per layer.
But if I tried to use a thickness of 1.2mm, I would get two concentric circles and then a jagged line between them.
Are there settings I can tweak to get 3 concentric circles in this case?
Thanks,
Bryan
Re: Walls exactly 3 nozzles thick?
Posted: Sun Apr 24, 2016 1:35 pm
There's several ways to do this, but it can vary depending on the model. It would be best if you just post your factory file so that others can give the best advice (go to File > Save Factory File).
