locdown
DaVinci with S3D Home Position
Good day everyone. Question. I have a Davinci with S3D and need the bed to drop about 10mm and the extrude to go back home after the print. How can i set that up? Thanks!!
Re: DaVinci with S3D Home Position
Have you tried just putting a G28 X0 at the end of your ending script? I would think that would home the nozzle once it's done.
locdown
Sorry for the delay.
so I go to FFF settings/Scripts/Starting Script and add G28 X0. Do I add semi-colon ( ; ) before the G28 X0? I do see ' ;G1 Z0.05 '
Thanks
Sorry, I meant to say ending script. Add "G28 X0" at the end of your ending script.
If you put a semi-colon in front of something, it is considered a comment and isn't sent to the printer, so don't put a semi-colon in front of any lines unless you don't want to execute them.
