CompoundCarl wrote:When I print different parts with different settings, I frequently have 5 or so parts on the build platform but I only have 1 selected in a specific process since I am customizing the settings for that one. Same with dual extrusion. So I think it's pretty common when you are using multiple processes.
Wait...!
You can have 2 processes on the same layers at the same time? I have not been able to get Simplify 3D to do that! It tells me the processes overlap.
I just tried it. Wow!!! Thats so COOL!!!
Position 2 objects on the plate separate from each other.
2 processes each with completely different settings ( I would assume temps settings would not work due to cool down and heat up time) without Layer Start or Stop set...
Select 1 object in the 1st process "Select Objects" button and select the other for the 2nd process. so each of the 2 processes only refer to 1 object.
Tell the slicer to print and select the 2 processes, you can do them sequential (ok, the temp changes would work in that case) or you can do then continuous, layer by layer (temp changes probably would not work).
Yet another way multi-processes differentiate S3D!!
However, the model selection button is still an awkward UI and it should be easier to do it in a way which flows along a task flow.
