What printer are you using? Did you make your own profile for it?
There's settings for flipping the XYZ axes and changing the axis directions, but you shouldn't need to adjust those if you are using one of the built-in profiles.
I am using an reprap i3.
This has never happened before with other prints.
It shows it as being correct in the preview, but when I slice it it changes.
