A Way to avoid confusion in the process
Posted: Fri May 06, 2016 4:06 pm
So many times I go from one printer to another... and one kind of filament to another...
Settings within the processes are hidden within their relative tabs and the only way one can be sure they are using the correct settings is to review EVERY tab EVERY time!!
But... how about if you guys changed some of the colors in the process dialog for each different material in the pulldown menu?
So for ABS you could use a light blue for all the field borders, PLA could be a dark yellow, etc...
Keep the colors consistent for the type of filament across printers and we will learn to use the color as an indicator as to what filament the process is set for right away.
