WISHLIST ' For devellopers'
Posted: Tue May 10, 2016 12:04 pm
In the top , the list and below you have the details
DUAL EXTRUSION not finish , make a big release , i prefer makerbot in dual , your software have no total respect of the tool change and make extra restart inside the solid layer , a big blob , in the layer , or change the toolhead just after the pillar layer , it's not serious , this software have no DUAL EXTRUSION engine , you have to finish it .
RESTART/EXTRA RESTART/TOOL CHANGE ; Please don't make this with static toolhead , it will makes blob and makes not desired ball , please wipe and move the tool head , it's not perfect solution but it's better than a big blob
Supports : impossible to had supports manually in some hole , we have to zoom , or go under the plate or HAVE CREATIVITY
Supports NOT INTELLIGENT !
Makerbot have intelligent support engine , the good positionning , the good angle for bridging , and when we reduce density of support , the engine is still very good
Please MAKE A GOOD RELEASE ! DUAL EXTRUSION AND SUPPORTS need to be improved
THks
*********** FEATURES REQUESTED **************
* G-CODE / LAYER
When setpoints needed , we have to know what layer exactly , in the preview mode you have ‘ doubled ‘ and we never know what layer exactly , in the g-code too , so please , respect the Z axis and name ‘ layer ‘ only the z axis movement , you have made tow layers for the same Z axis movement in your software ‘ when dual , or pillar , or ozz ‘ are enabled , but when only one extruder all is right . For example i have dual extrusion object , temp of the left can be stopped for the first 140 layers , we have to program the first layer to stop , the next to turn on , the next to turn off , Please offer us the possibily of the TRUE LAYER ‘ no doubled , no divided ,only the true ‘ ,and the possibility of ‘ MILLIMETER oh yeah would be perfect ‘ , and modify the preview interface to have the true layer shown , and not a doubled !
* PREVIEW :
- Need number of the layers !!!! 'for example to have the exact layer for some setpoint , when dual extruder not utilised during many layers we want to low the temps , but we don't know exactly the first and last layer '. Now , the number of layer is false when have ozz shield , the number of layer is doubled and no the true ‘ z axis ‘
* SETPOINTS : In millimeters or Layer Number please !!!! It's not easy to find the exact layer sometimes it must be amazing to enter the value in ' millimeters ' for french user of course ' .For example , i need to put temp setpoints for the second extruder used only after 60 millimeters of printing , i would put a temp setpoint a this value , not with a layer value that i have to calculate.
* SETPOINTS CONVERSION
When settings temp setpoints ' in millimeter ' , we don't have to recalculate them if we change the layer size , it's the big advantage to set them by entering metric values and not the layer
* SETPOINTS : From bed , or from first layer of printing ???? , for example , if i have dual extrusion and the first extruder will begin after 700 layers , the first setpoint is the bed ? or the first layer of printing first time by the second extruder ?
* TEMPERATURE OF EXTRUDERS in PREVIEW : For example , we need to verify temp changements , so , make the option in the preview mode , we will verify all our setpoints and will be sure of our setpoints
* SETPOINTS: Make an option that make automatic setpoints to low down the temp , when extruder not used during a number of layer ' for example , the first layer of the second extruder is active only after 700 layers ,it will be amazing your software make automatic temp points. No Ozzes and perfect dual printing , no electricity consumption , and machine life increase !
* COMMON PILAR AND COMMON SHIELD FOR ALL !!!!
For example , the first process have pillar and ozz shield , all is ok...If the second process is the second extruder for dual extrusion , impossible to use the actual pillar with the second extruder , to make it , we have to group the processes !And it's very important to extrude in the pillar when the second extruder starting his first layer, not very common !!!!! and not common for all the next processes !
* COMMON PILAR AND COMMON SHIELD FOR ALL !!!! AND ALL PROCESSES NEXT !
Exactly like i said just before , but , for all processes , because if the second process have a starting point later than the first , the process can't use the pillar
When finish a first process , it will be amazing , the second process could continue the shield and the pillar
Pillar and shield , must be INDIVIDUAL PROCESS avalaible for all processes that have this option
* OZZ SHIELD VIBRATION WHEN CURVED
I don’t know why the printing of ozz shield is step divided or something that makes vibrations , and never print a silent curve , so , for this problem , we cannot increase the speed , too afraid to damage the machine that makes jumps on the table
PRINTING :
- ANTI SHAKING OR SPEED REDUCTION WHEN MANY DIRECTION CHANGEMENTS WITH LITTLE DISTANCE : Increase the speed when printing continuous trajectories , but reduce the speed when printing ' upstairs or many little distance in many direction ' , because , i have the sensation the printer will explose or will not survive !!! I don't want to reduce total speed , just some movements that shake too much the machine !!! BIG OPTION !
* INTERFACE :
-POSITIONNING TOOL :Utility tool to assist for dual positionning of two parts , now we have to checks x,y,z axis and have many creativity to make the perfect matching .Just like ' connect surface with surface like solidworks '
-UNITY OF MESURMENT : Possibility of changing the unity of speed , in mm by second , because by ' minute ' , it's not CLEAR for the brain lol
* SUPPORTS :
-POOR SUPPORTS WITH INTELLIGENT DENSE LAYER
Make a very poor support and , make a beautifull last layer ' like DENSE OPTION' just before the solid layer ' why ? Intelligent support generation can divide printing , and make gain of many hours. Poor supports combined with intelligent DENSE OPTION , will make economy in time , in electricity in plastics and the machine too
-IMPROVED MANUAL SUPPORT GENERATOR , make us , a solid support designing tool , because now it's prehistoric system, eraser like pencil , because i become mad when i have 2500 clics for erasing ! and of course , pencils for painting support with magnetic alignement and many sizes avalaible.
-INTELLIGENT SUPPORT SLICER , no support in void or with nothing under ...
-SUPPORTS DESIGN PRIORITY : Supports must have absolut priority to make their job , so to make a layer that permit to print a solid layer , so , don't give the absolut priority to the ' percent amount of support ' , the first priority is to make a good support , if generator is intelligent , it will make no stupid support design or uneeded or in the void . Make bad supports if you want , but , make the last layer with an intelligent DENSE layer like i said before
- MIXED MATERIAL SUPPORTS , makerbot make that , support white for white solid layer , support black for black solid layer , or just the first ' DENSE LAYER' before the solid , because supports and solids of diffrents colors make the print dirty
-INDIVIDUAL SUPPORTS FOR EACH PROCESS :When group of process , leave ' supports ' individual for each color , for example if i want to deactivate support for the second color , it's impossible , i have to ungroup and regroup
-SINUSOIDAL GAPING AND FILLING , to have more smooth whe printing
* TEST BOARD OF MATERIAL
Please create for us , a big factory file , that can permit to check our setting for each material used . For example , you make some draw , to test many setting of retract , and when printing finished , we will see what setting is the better, and so , for the solid speed printing , we will see when extrusion is out of limit , you can make some long square and each have some incremented settings , after the printing we will see what is the limit
It’s a very good thing , this factory file , or may be , many factory file , to know exactly what are the setting of the printer , the material
Solid speed printing , retract , extra retract , temp , a large and big print at once that said all we need to know about the printer and each material tested
BIG BIG THING !!! I want to create it , but , if you can make it , it’s better !
THks
* G-CODE / LAYER
* PREVIEW :
PRINTING :
* INTERFACE :
* SUPPORTS :
