Script or MCode for home X & Y axis at end of print job.
Posted: Sat May 14, 2016 5:45 pm
Hi folks -
I have noticed that whenever I create a print file (gcode) for my Prusa I3 machine,
the hot-end will stop right on top of the printed part when the print is finished, cool off, and get stuck.
I checked the settings in S3D and it seems that there is no code telling the X & Y axis to go home after the print has finished.
I used to use Cura exclusively and the X & Y always homed at the end, leaving the part accessible.
Can someone help me out with what mcode to put in the 'end script' tab? I'm not very gcode savvy
so this is a bit of a mystery.
Thanks! - JD
Thanks! - JD
