Extruder head smacks side at start
Posted: Mon May 16, 2016 7:29 pm
Hi all,
I have a QIDI Tech 1 printer, mostly identical to a Flashforge Creator Pro. Per the manufacturer's suggestion, I use the "Makerbot Replicator Dual " settings, and for printing, they've worked perfectly.
My problem came after adding an included fan to the side of the print head. When I print, the device always moves to the far front left of the cage, well past the print bed. Now that the fan is added, this means it smacks the edge really hard, and holds there for 5-10 seconds.
I can still technically print once it decides to move on to the next step, but I'm really worried it's damaging the printer. Where can I edit this setting to adjust it's "start" position without affecting the print alignment?
Thank you in advance for your help!
