I am printing the Bonsai Planter by gCreate and need to have top layers in order to print some of the slopes correctly. I could use stop and start printing functionality, but that a top layer blocking off most of the main volume of the planter.
The perfect solution would be to be able to cut off the top. When you select stop at height, S3D still adds the top layers as expected.
I could stop the print but that's feels clunky. The best option would be to tell S3D to simply cut off the top AFTER all the other slicing is done. Is that possible?
