Infill
Posted: Tue May 24, 2016 10:44 am
by gwcrook
All of my infill goes in the same direction. Regardless of the angles I select or the patterns selected (honeycomb, wiggle, triangle) it only prints straight lines one on top of the other. Can some on point me in the right direction. BYW I have been using S3D for 3 days.
Gerry
Re: Infill
Posted: Wed May 25, 2016 6:05 am
If you're using their stock profile, you should need to do anything besides select "rectilinear" as your infill pattern. That will print infill in 2 directions (+45 degrees and -45 degrees).
Have you done that already? Please post your factory file and a screenshot if that still isn't working (you can create a factory file by going to File > Save Factory File)
Re: Infill
Posted: Thu May 26, 2016 1:54 pm
by gwcrook
I changed the name and it helped. Thanks.
