Infill
Posted: Thu May 26, 2016 2:10 pm
by gwcrook
I have been trying to get the infill to be 100%. I need the weight to keep the item upright. I have attached the factory file. The Bottom process should have 100% infill but it instead does not fill in the entire are.
PS - I know the Bottom1 process does not process the entire cone. The cylinder with the tabs is supposed to be basically hollow with 5% support material to support the top of the cylinder.
Thanks
Gerry
Re: Infill
Posted: Fri May 27, 2016 7:49 pm
by Rebekah_harper
hiya,
this was not designed as a solid base. having said that I can see what you did there filling it with support material.
I am not sure what you were trying to do with the start stop function. as you were missing parts out.
so I gave it a guess and created my interpretation of what I think you were looking for.
I added some dense layers to the top half of the support structure. I don't think you would have gotten a top layer on what you had.
hope this is what you were looking for
if i managed to get it right and you want to know more of what I did. please send me a message and I'll be happy to explain.
Becky
Re: Infill
Posted: Fri May 27, 2016 8:12 pm
Do you get what you're wanting if you use the Separate Connected Surfaces option on the Mesh dropdown menu????
The model as it is appears to have a large void inside it...which is why you get support instead of infill. Separating the meshes out, the slicer then merges them back together into a solid object.....and you get infill instead of support!
