bed leveling - fixed bed plate
Posted: Mon May 30, 2016 3:45 pm
by mikeysmailbox
Hi
I have a Printrbot Metal Plus Dual and it has a fixed heated bed.
I can't get the simplify3d to level correctly.
I may be doing this incorrect as I adjust the Z height using the Jog Controls and not adjusting the print bed.
Is there a way to adjust the simplify3d with a fixed bed?
Maybe its just the auto level built into the Printrbot.
Thanks
Re: bed leveling - fixed bed plate
Posted: Mon May 30, 2016 6:31 pm
On the "G-Code" tab of the FFF Settings is a field Global Code Offsets - Z-axis. Putting a positive value in there will move the extruder away from the bed, and a negative value will move the nozzle closer.
This setting will save with the profile so you can use it again...is this what you're looking for??
