Not able to print the part
Posted: Thu Jun 02, 2016 11:46 am
I am starting using Simplify 3D after Cura. I use a Mankati XT plus printer and use the default settings for the printer/
I have tried to print the following part with S3D, using PLA at 210°C, 0.1 layer height, 45°C Bed : http://www.thingiverse.com/download:1699292
The first layer is very good, and the base of the vase is solid with very good finish, no delamination, no holes.
But as soon as the printer starts printing the rest of the vase, mainly pillars with lots of retractions, I face bonding issues and after a couple of layers, I have a split with the base and the printhead is printing in the air.
I've made 3 tries, with different temperatures, but no success.
I have finally used cura to print successfully the part at 210°C, bed at 45°C, 0.1 layer height with the same PLA filament.
I have printed other parts with the same filament without any issue.
I believe some default parameters in S3D are not correct around retraction.
Your help much appreciated.
David
David
