Changing speed during print
Posted: Sun Jun 05, 2016 6:35 am
I have a print with two quite different halves. The first is very standard and can be printed quickly, while the second consists of lots of thin parts which I need to print slower.
Is there anyway to change the speed half way through the print using Simplify3D. I can't see any but thought I'd double check in case I missed something.
I'm thinking I might need to alter the gcode myself but have not done this before so just trying to research what would be required. If anyone has any advice here I would really appreciate any tips or resources.
I did find this comment on another forum so hoping I could potentially add the M220 command halfway through the gcode where I need it.
"You can also adjust a global speed modifier in Marlin to suit your needs. Impatient? M220 S150 will speed up everything to 150%. M220 S75 will slow it down to three-fourths of the planned gcode speed. M220 S100 will restore timing to what the slicer produced."
Cheers,
Chris
Cheers,
Chris
