Hi ..... yes I new
I have a dual ext 3D printer and I want to be able to print my part in ABS and the raft and supports in PLA. I am using Simplify3D
HOW? please help
Thank you very much. I still have a lot to learnandrewk72 wrote:Just select "Both Extruders" for the auto-configure extruders option and then go to the Temperature tab and edit the temperatures for the left and right extruders as needed.
You can then select what extruder is used for the part, raft, support, etc. It's all in the process settings.
Have a look at this thread....if you haven't already. It explains every setting in the print profile...some in great detail.Is there a document that enplanes all the setting ?
