s3d not generating support
Posted: Tue Jun 07, 2016 12:42 pm
by bleeps
I'm not sure why this feature isn't working. I've been able to generate supports on other files before. Suddenly it's not working on any model I try. The Factory File is attached. Am I overlooking something?
Re: s3d not generating support
Posted: Tue Jun 07, 2016 2:42 pm
by andrewk72
Your support pillar resolution is far too large for your model. Those beams are only a few millimeters thick, so you need to lower your pillar resolution to 1-2mm
Also, you might want to save some of those processes as actual filament or machine profiles. That makes things much easier to work with ;)
Posted: Thu Jun 09, 2016 4:57 pm
by bleeps
That was it. Thanks!
And yes, I need to work on my workflow. I haven't done enough reading on what the different file/profiles save.
Posted: Sun Mar 10, 2019 2:08 pm
by fbrier
Thank you. This was my problem as well. :)
