Large surface separation
Posted: Tue Jun 07, 2016 9:39 pm
When printing large flat surfaces, the surface starts to separate into strips. The surface looks good near the edges but gets worse as you move toward the center of the surface. The attached pic shows an extreme case from a test piece I made where some of the strips completely pulled away from the surface. They usually just leave a rippled effect on the surface which can also be seen. I appreciate any help.
thanks
thanks
