Geeeetech Kossel Mini
Posted: Sat Jun 11, 2016 11:04 am
Hi everyone,
I recently bought this little delta printer, and have now finished building it. I have done the calibration and will more than likely need to do it again once I have let it settle in.
I need some help, please with the start and end scripts. I am using Simplify 3d, and have got a profile from the support team, but it does not work. The axes look like they are confused, and trying to print the part sideways. I have partial success using the Kossel Mini profile in the directory, but when starting the print, the nozzle sits on the table while all the heating up takes place, which burns a small hole in the build plate, it then goes to the home position and starts the print cycle. Once the print is complete the machine goes to the home position, but then switches the motors off, so the nozzle drops down onto the finished print.
I hope this all makes sense. I have attached the gcode of a simple test 10mm x 10mm square.
If anyone can help me I would be most grateful.
Thanks in advance,
Tony
Thanks in advance,
Tony
