BFB 3D Touch - Not working
Posted: Sat Jun 11, 2016 1:55 pm
by scribe-eng
Hi there,
Can someone please help
I have purchased this software as I have been told it works with all my printer, I have a BFB3000, 3D Touch and a cubeX but my main one is the 3D Touch but the profile I have does not work as it will not extrude but it does prime,
is this a ongoing problem?
does someone have a fix?
am I going to have the same problem with all my printers?
Re: BFB 3D Touch - Not working
Posted: Sun Jun 12, 2016 7:03 am
The cubeX is really similar to the CubePro, so I doubt you will have any problems with that one. You can probably just modify the current cubepro profile (or email support and maybe they already have a cubeX one)
The BFB3000 and 3D Touch are quite a bit older, so there's probably some differences with how they operate and what syntax they need. Best thing to do would be to compare a BFB file between all 3 machines to look for differences. If you post the BFB files here, other's can probably help too
Posted: Mon Jun 13, 2016 12:58 pm
by scribe-eng
please find attached g-code files for the same part.
Test Print - axon.bfb is for the BFB 3d Touch as exported by the Axon software
Test Print - Test Print - touch-bfb.bfb is for the BFB 3d Touch as exported by the Axon simplify3D
my main immediate problem is the extruder doesn't extrude but it will prime before printing on my BFB 3D Touch
could some please have a look at the attached files as I have no experience with G-code and tell me what's wrong.
Posted: Tue Jun 14, 2016 10:35 am
by BaudR8
This probably wont fix all of your problems, but it looks like your test print -touch-bfb.bfb file has double line spacing (see screenshot) which is not right.
Ive attached a new.bfb file that is the same exact file as yoru test print - touch-bfb.bfb file except the line endings are fixed from 0D0D0A to 0D0A
Posted: Thu Jun 16, 2016 6:28 pm
by scribe-eng
thanks BaudR8
Posted: Wed Jul 27, 2016 3:04 am
by Demen
Hello,
I received the software from simplify3D about one week ago and a took me some problems to get a working profile. At first I downloaded the profiles from here viewtopic.php?f=8&t=3113&hilit=tip+of+the+dayand used the dual extruder profile which is a bad untested profile. I encountered two problems an one of them was the line endings as suggested by BaudR8. To overcome this remove the line:
{REPLACE "\n" "\r\n"}
from the FFF settings in the tab Scripts.
The second problem was that the printer started to warm the third extruder before starting te print. To overcome this remove line:
M553 P64000 S600
After doing this the printer started to print although the results was nog very good. With a profile I got from the support I adapted some filament settings and now the prints are better. Still some improvements needed, but it is geting better.
