[ADDED] Gap Filler To Improve Surface Finish
Posted: Sat Jun 11, 2016 5:40 pm
Please implement adaptive extrusion width to fill small gaps on the perimeters. You should allow the user to select the minimum allowable extrusion width. This will greatly improve the surface finish on some parts.
The current implementation of gap filler (Thin Wall Behavior) by allowing a % of perimeter overlap does not work as well as the above recommendation.
