Long (24hr+) print from SD stops, incomplete
Posted: Sat Jun 11, 2016 10:20 pm
I'm trying to figure out what is happening, and am hoping someone can assist...
I'm running a 24hr+ print from SD using S3D (latest and previous versions both failed) and the print job stops before completion. It seems that with the latest version of S3D, I got a bit further (not sure if there is really a correlation)..
I've tried different SD cards too.
I'm running a Makergear M2 (dual)....S3D is running on a Windows 10 computer..
Is there a way to have S3D do a print from SD and then disconnect? I'm trying to determine if it is S3D's connection to the printer, or the printer itself having an issue....
Any help would be appreciated ...
Thank you
Thank you
