Keep folders for import, save, etc.
Posted: Mon Jun 13, 2016 6:21 am
by TMeyer
Dear all,
Usually I use a certain folder where I import my STL files from and another folder where I save my gcode files to.
Currently (S3D V3.1) if I save a gcode file in lets say C:\gcodes and then I import a new STL file S3D shows the C:\gcodes folder again.
But the C.\gcode folder is not where I import my STL files from! I want to import from C:\stl.
So what I wish to have is that S3D remembers the folders separately.
On importing files S3D should always open the import folder (the last one I used for importing, here C:\stl).
On saving gcode files S3D should always open the 'save' folder (the last one I used for saving, here C:\gcode).
Thanks...
Re: Keep folders for import, save, etc.
Posted: Mon Jun 13, 2016 9:55 am
I think this is already in the software. If I click Import to load a model and browse to C:\Models and import a part from there, and then save my toolpaths to C:\Toolpaths, it remembers both of those paths correctly. Any time I go to import a model in the future, it automatically starts at C:\Models and anytime I export toolpaths, it starts at C:\Toolpaths
So I would say the current version already does this correctly
Posted: Mon Jun 13, 2016 10:19 am
by TMeyer
Hi CompundCarl,
I forgot to mention that I use the (latest) Mac version - May it is a Mac (only) problem?
Posted: Mon Jun 13, 2016 12:11 pm
by TMeyer
I double checked now.
I saved a gcode file in my filder UM2/gcode.
Then I wanted to import a new model but S3D presented the UM2/gcode folder again and not the folder I used last time for importing STL files.
May some Mac user can check this as well?
Thanks...
Posted: Mon Jun 13, 2016 3:46 pm
by theDiver
The mac version has the same, quite annoying problem.
They should fix it at once.
Posted: Mon Jun 13, 2016 5:27 pm
I have 2 different macs here that are both running different version of OS X and both of them work correctly. So perhaps it only affects one specific OS X version.. either way, that probably means that apple changed something that's causing the problem, because I can definitely confirm that it works perfectly fine for my Macs and I'm running the same version of the program you are
Posted: Tue Jun 14, 2016 2:55 pm
by TMeyer
today I tested again and I still have this problem on my Mac!
My Mac El Capitan is version 10.11.5 (15F34)
Posted: Wed Jun 15, 2016 8:31 am
by Count_Carstein
Have the same inconvenience on my Mac
Posted: Thu Jun 16, 2016 6:21 am
What version of OS X are you using? It works fine on several of my macs, so it must be only a specific version of OS X that has this problem
