Print "pauses" on SD or USB
Posted: Mon Jun 20, 2016 9:03 pm
by gregthoman
After the first layer or so, the print will "pause". If I'm running in USB control mode, I can press pause and the resume and it will keep going for a layer or so. On SD, The printer pause and resume commands do not work. This problem just started after a brief hiatus of just a couple weeks. I don't think anything changed. Any thoughts?
Re: Print "pauses" on SD or USB
Posted: Wed Jun 22, 2016 7:03 am
If it's pausing from the SD card, then it sounds like you either have a bad command in your gcode or something is wrong with your firmware
Posted: Thu Jun 23, 2016 4:43 pm
by gregthoman
It's pausing regardless. But I will try updating the firmware on the printer. Thanks
