DaVinci 2.0A heating
Posted: Tue Jun 21, 2016 12:20 pm
by Jenne
i use PLA on the left printhead, therefore i had deactivated the heating of the right extruder and the heatbed in the process by setting them to 0..
However the DaVinci always starts by heating up both extruders and the heatbed according to the chips from the cartridge, then cools down and starts printing after reaching my desired temperatures.
Is there a way to supress the firstheating and start directly with my temperatures ?
In the start script in process there is no setting for the temperature.
Re: DaVinci 2.0A heating
Posted: Wed Jun 22, 2016 7:04 am
I believe this initial heating is hard coded into their firmware. You can't disable it, so it always has to heat to this initial temperature, and then it will go to the temperatures you defined in S3D after that point.
