Modifying profiles - add item to list
Posted: Mon Jun 27, 2016 5:02 am
Welcome,
I have several materials from several manufacturers. It means that "ABS1" is not the same as "ABS2", also settings for material depends of printed object.
Because of that I don't use "Auto configure for Material" and "Auto configure for print quality". I just have full profile for some materials in "Select Profile". And everything is working OK.
When I select profile (let call it "PLA") all settings are from that profile. Now I change ex. speed and my "PLA" is now "PLA (modified)". Next I want to create second process with settings from "PLA" but I have to use modified "PLA (modified)". It means I need to compare settings to have pure "PLA" or create a lot of temporary profiles (I have a lot like "q1", "q2", etc) which is horrible. Also when I want to change profile for some process there is a question if I want to save profile modifications...
Please add 2 things:
1. when I change profile there is a question "Do you want to save the changes you made to "PLA"?". There are buttons "Yes" and "No". Please add also "Abort" to abort operation and not change anything,
2. if I modify profile "PLA" please add next profile named "PLA (Process 1)" only for currect file. Activating this option may be in program Configuration.
