S3D crashes whenever I run configuration assistant
Posted: Tue Jul 05, 2016 2:10 pm
by billyd
I need to swap configs for two different printers with S3D. Just recently S3D crashes whenever I try to run the assistant.
How do I fix this without an uninstall reinstall? I don't want to lose all my processes. And export import of the files is not a great option either. I am looking for a quick simple fix. It is obviously a corrupted file. Which one is it, and how can I fix it?
Re: S3D crashes whenever I run configuration assistant
Posted: Tue Jul 05, 2016 4:01 pm
You really only need to run the configuration assistant once per printer ever! You don't need to run it every time you want to use your other printer...see this thread:
viewtopic.php?f=8&t=5499&p=23838&hilit= ... ers#p23838
Posted: Tue Jul 05, 2016 4:05 pm
by billyd
I was told to use it when switching between printers by S3D. I can use the method you linked to in the future thanks.
Unfortunately now my machine crashes whenever I run it. So I will need to fix that at some point. Any idea how?
Posted: Wed Jul 06, 2016 5:48 am
The typical recommendation is to go to Help > Reset All Settings, so if you don't want to do that, not sure what to do...
