Hello,
I have two processes. One process is dedicated to my first layer, I use 0.4mm layer height in this process with a 75% first layer height. The process ends at 0.3mm so first layer is controlled best for adhesion. I set my hotend temperature in this process to 235 to help with adhesion. And then my next process is dedicated to the rest of the part with a different temperature.
The problem is, S3D is calling for a different first layer hotend temperature; totally different from the one I specify in the first layer process, I look at the LCD screen and the readout targets another temperature something like (220/220). If I change the process to a new temperature, between the time the bed performs the G29 ABL command and the first layer, the temperature target changes. It's all over the place, not sure what is going on. I need to be able to change the target temp reliably.
Thanks for the help
