Hello all.
I'm having a new problem with my software crashing. I've used Simplify3d with my Robo 3D r1 since March with no problems. I opened up the software today after not using it for a few weeks and once I get the "Device Connected" notification on the bottom right a few problems pop up.
First the build table immediately disappears leaving me with a blank blue window.
Then sometime after the software will crash and Windows 10 will give me the "stopped working" notification.
What I've done so far.
Updated to the latest version 3.1
Uninstalled and removed license, then re-downloaded and reinstalled 3.1
Updated video card drivers.
Tried different USB ports
During the time before the software crashes and closes itself I can open the machine control panel and send axis moves to the printer and it responds correctly.
Communication log if that helps:
Connected to machine!
READ: echo:Marlin1.0.0
Marlin1.0.0
READ: echo: Last Updated: Jun 24 2015 14:05:08 ho: Free Memory: 3749 PlannerBufferBytes: 1232
READ: echo:Stored settings retrieved
READ: echo:SD init fail
SD init fail
READ: start
SENT: T0
Marlin1.0.0
READ: echo: Last Updated: Jun 24 2015 14:05:08 | Author: (RoBo 3D, R1 Single Extruder)
READ: Compiled: Jun 24 2015
READ: echo: Free Memory: 3749 PlannerBufferBytes: 1232
SENT: M105
SD init fail
READ: echo:Active Extruder: 0
Active Extruder: 0
READ: ok
READ: ok T:26.3 /0.0 B:25.7 /0.0 T0:26.3 /0.0 @:0 B@:0
SENT: M105
READ: ok T:26.4 /0.0 B:25.8 /0.0 T0:26.4 /0.0 @:0 B@:0
I'm looking for advice on what to try next.
Thanks
