starup sequence for velleman vertex k8400
Posted: Sat Jul 16, 2016 3:18 pm
by Tiny-Tim
hi i just bought the program and i have a newly built k8400, i have gone through the setup process and started to print my first print but the printer says "waiting for bed to heat" the k8400 has no heated bed from factory how do i fix this ?
Re: starup sequence for velleman vertex k8400
Posted: Mon Jul 18, 2016 8:39 am
by Heutinck
edit your process settings. go to the temperature tab. select the heated bed and then at the bottom left corner there is a button that says remove temperature controller. this should get rid o f it, and then just save the profile.
Posted: Thu Jul 21, 2016 5:45 am
by Tiny-Tim
hey, thanks it worked, i also contacted support to let them know that stock the k8400 doesn't come with a heated bed, they also sent me a revised FFF file for the program so that i didn't have to fiddle with it myself (i'll attatch the file if anyone else needs it)
Velleman_K8400_PLA.fff.zip
This file contains both windows and mac files
(3.04 KiB) Downloaded 405 times
