isacat
how to fil
I am new with S3D and I have this issue, there is a slit visible, on the stl file it's all nice close
anybody know how I can close this gap (slit), like for example a extra line filament in the middle will close it?
Re: how to fil
Just set your extrusion width to manual and then increase it by a small amount (like 0.4mm to 0.42mm) That will be enough to fill the gap.
isacat
Re: how to fil
how do I do this, I just stared with 3D printing
Re: how to fil
Click "Edit Process Settings", go to the Extruders tab, click on the extruder you are using from the left-hand list, then set the extrusion width to manual and enter whatever value you want. Then just click OK and then "Prepare to Print" again to see the changes.
You should only need to increase your extrusion width a tiny amount, so if it was currently at 0.4mm, only increase to around 0.42mm or something similar
