So, with all this Pokémon Go craze, I decided to print out a Pokeball. And I came back to an interesting situation: when printing half a sphere, which is the best orientation?
a) open side down - most amount of support needed, top part of sphere suffers from layer granularity, that is, small curves relative to the bed over a large model creates a 'step'
b) open side up - less support needed (significantly less then a) still has layer granularity
c) open side horizontal - ????? Probably the best, but takes the longest amount of time.
Although this is just a general case, it would be nice to handle much more complex model. I envision this like a "driving planner" --- Three choices available - fastest, shortest, best gas mileage, for example. Simply3D would take existing print parameters and give you multiple options. I bet some solution would be not-so-obvious, like 75 degrees from the horizontal.
You could use the 'auto-support' parameters to rotate the model and calculate optimum rotation angles for least filament, 'speed' options to determine fastest print rotation and 'layer' options to determine best quality rotation.
The reason this would be great is because it would help inexperienced people to get good results and be able to compute various options faster than experienced people.
(ps. if you like this idea, send me a free t-shirt, men's medium/large)
--Ken
