Multi Layering for a mug
Posted: Tue Jul 26, 2016 3:09 pm
by killonious
Hello. I'm trying to print a solid object as a mug. To do this I'm printing zero infill and top layers zero. The object prints well except for one spot. Since I have top layers set to zero, there is a spot on the mug that the object is horizontal and does not print so there is a hole in the mug.
To fix this I tried to use multi 3d printing processes. The first process has the bottom and top layers set to 4. The following process has the bottom and top set to zero layers. I set them up to stop and start at the same level. The problem is, the sliced image shows a top layer where the processes switch. Is there anyway to set this up so my mug is completely hollow and I don't have holes where my object goes horizontal?
Re: Multi Layering for a mug
Posted: Wed Jul 27, 2016 6:34 am
Can you hollow out the 3D model so that it's a shell? That way you wouldn't have to set infill to 0%, and you could just use support structures to support that one small overhang
