Raft Failure with Dual Process Build.
Posted: Fri Jul 29, 2016 3:16 pm
I'm trying to do something like this:
https://www.simplify3d.com/support/arti ... f-a-model/
Where I have slow, thin layers to make the bottom of my part clean, then thicker, faster layers to speed up completion of the part. Here is the final path plan with the red arrow showing my switchover: But here is the raft: The supports built on air are causing a big mess. I can fix the raft by moving the thin layer all the way up to the red arrow, but I've lost most of my speed gains if I do that.
Any ideas on how to fix this?
I'm running simplify 3d version 3.1.0 on a 3dp1000 printer.
Thanks in advance,
Chuck in NYC
Thanks in advance,
Chuck in NYC
