Struggling to Print Small Areas
Posted: Tue Aug 02, 2016 1:22 am
by Tetraodon
I'm really struggling to print this "grid" which has an area of around 2.6mmx4.2mm for each column. Variables I've ruled out are:
- Build plate height
- Warping (the plate is warped, but the same pattern emerges no matter where it is on the plate)
- Filament type (two different brands of filament, ABS)
Of course, there's a bunch of different parameters I've tried ruling out.
- Overall Speed doesn't appear to affect the quality
- Outline Speed doesn't appear to affect it
- Gap Infill doesn't appear to have any effect
- Extra Restart Distance doesn't appear to have any effect
- Retraction Speed doesn't appear to have any effect
- Retraction Distance doesn't appear to have any effect
- Extrusion width doesn't appear to have any effect
- Adjustment of print speed reduction (if under x amount of time) doesn't appear to have any effect
- Reducing Extrusion Temperature doesn't appear to have any effect
And then there's ones that have me confused.
- Retraction - increasing the number of retractions seems to make it worse.
- Turning off Coasting and Wiping looks like it may have made it slightly better?
Below are some pics:
Increased Retractions:
Changing different parameters:
Most recent file's print:
The factory file:
160802 Moss Tube Outer.factory
(311.84 KiB) Downloaded 296 times
Any thoughts as to what might be going on? I know each bit is a very small area to print on, but it's making it very difficult to print this and other mechanical parts that are delicate to print.
Thanks in advance for any help :)
Re: Struggling to Print Small Areas
Posted: Tue Aug 02, 2016 7:09 am
by wirlybird
I am going to guess here and say keep lowering the temp. I have some small parts with posts that string real bad in-between the posts. I kept lowering the temp, I'm using PLA, until it stopped. A 5 degree change back up was enough to start the stringing again. I mention stringing because I was also getting those blobs along with the stringing. Don't know if it will help but just looked kind of the same.
Posted: Tue Aug 02, 2016 7:35 am
Looks like you need to work on your retraction settings to me
