Shifted automatic support structur
Posted: Fri Aug 05, 2016 11:34 am
by nilsgollub
If I use the option "generate automatic supports", the support structures are often shifted a few millimeters like you can see in the picture. Does anyone have an idea why this happens?
The support structur is nearly as wide as the overhang, but because of the shifting, the half of the overhang is unsupported.
Re: Shifted automatic support structur
Posted: Mon Aug 08, 2016 10:37 am
by Heutinck
It wants to put two rows of pillars in so it overhangs a bit but you pillar resolution is too large. lower the resolution of the support pillars and it will put in a second row.
Posted: Tue Aug 09, 2016 4:15 am
by nilsgollub
Heutinck wrote:It wants to put two rows of pillars in so it overhangs a bit but you pillar resolution is too large. lower the resolution of the support pillars and it will put in a second row.
Thank you. I will try this...
