I have a part that is essentially a cutout of a pipe. The inside of the pipe has purposeful extrusions and needs to be supported when printed. Automatic generation of support places 0 supports on the drawing. Trying to place them manually has been impossible. The tool won't even allow me to move a support under the top extrusion. I need to print in this orientation for strength. Although I have tried rotating it so the extrusions are rotated 90 degrees just to see if I could place a support. Isn't there some way to tell the support engine to support internal parts? That top extrusion is obviously not going to print.
My work-a-round is to redesign the part with a piece of plastic printed between the extrusions.
I added the internal piece and tried the auto support again and got this (which I can now use). Note that the added piece is just 0.2mm x 0.2mm:
