Change extruders at certain layer
Posted: Mon Aug 08, 2016 11:13 am
I've done a few dual extruder prints with the dual extrusion wizard where I have two STL files for a model specifically designed for dual printing.
However, what I'd like to do - and I'm not sure how - is print a simple STL file and change extruder (for another colour) half way through.
I tried to do this by creating two processes, one for PLA / Right extruder only and one for PLA / Left extruder only. I then used the start print at height / stop printing at height options so that the processes only apply to certain layers. When I "Prepare to print", in the select processes dialog, I Select all and click ok. But then I receive a warning "The selected process is not configured for the number of extruders you have chosen to use"
So i've not proceeded. What should I do? This must be possible but i'm not clear on how.
thanks
slip
thanks
slip
