CompoundCarl wrote:Well, if you want you can of course double-click on the part, disable uniform scaling, and then change the Z-axis scale. But as to WHY it's happening, since your part it only 2mm tall, it's going to be easily affected by your first layer height. If you are squishing the plastic on the first layer a bit too much, you're going to end up with a part that is a bit too short.
Makes sense, I think my first layer settings are 90% height, 100% width. not home to double check! Running the basic PLA profile for the QIDI.
I tried a 25 X 25 X H35 cube with 1 shell, 1 bottom and no top or infill and it was about .1 - .15mm short.
Maybe I am nitpicking here and if these are the tolerances I can expect then that is ok I can work with it but it seems to be a bit much and I am still learning on all of this!!
I was thinking I will try a solid cube to see how that goes.
I have just changed over to Flexion extruders and am trying to get them dialed in. I hade pretty good dimensions before so I think it is capable!
Thanks for any suggestions!
