CompoundCarl wrote:Probably just residue left on the bed. That's what usually causes this problem for me at least
I thought so also but this was a fresh just coated glass.
If you look toward the bottom of the circled area you can see a line starting at the left edge of the print and going to the right then it curves up where it defines the recessed area. The interesting thing is that this shape is exactly the same as the right hand side of the cutout in the middle of the print. This pattern is repeated on the other piece printing next to it (same part). It's like it got a ghost outline from the opening in the middle that shifted on the print.
I have printed several of these and it has not done this but I was printing one at a time.
I am going to try to print a single again later to see what happens.
The only things that change hardware wise are new extruders and Y axis belt tightening.
