delta printer parts sloping
Posted: Fri Aug 12, 2016 6:57 am
by MDMTom
so im having an issue printing at any speed on my 2 delta wasp 2040 turbos.
and i was hoping someone might have an answer.
printed at ranges from 120-250mm/s at 210c in fiberforces high speed PLA, perimiters are set to 60%
seems to follow the long axis with whatever orientation i put it in s3d with.
however using Cura i get perfectly straight results! much worse surface though compared to when s3d works well.
any ideas to help fix this?
Re: delta printer parts sloping
Posted: Fri Aug 12, 2016 10:01 am
I know there is a known bug with one of the old firmware versions that caused this, but I'm pretty sure that was at least 1.5-2 years old. So hopefully the deltawasp people have updated their firmware branch recently and aren't using some really old version. You can of course ask them though. If they tell you they are using a branch of Marlin/Repetier from 2014 or 2015, then that's probably what the issue is.
If I remember, the solution back then was to go to the G-Code tab and disable "allow zeroing of extrusion distances (G92 E0)". Of course, there's no reason to do this except for the fact that the firmware had a really bad bug that caused the shifting.
Besides that, you can look through the gcode file that S3D created. If you don't see slanted coordinates in the file, then something else with the machine must be causing the issue (perhaps skipped steps or bad motor current?)
Posted: Mon Aug 15, 2016 4:45 am
by MDMTom
Excellent! cheers for that ill trial disabling the extruder zeroing while i wait for an update on firmware version.
many thanks
Posted: Fri Aug 19, 2016 12:39 am
by rrapier
Thank you so much for posting this!!!
I have been going crazy trying to figure out why simplify3d was causing prints to get skewed. every single google answer on earth is "check your belts"
I have no problems printing in slic3r or whatever, but damn i wanted simplify3d's smooth and speedy prints!
thank you again CompoundCarl
Posted: Sun Aug 21, 2016 8:17 pm
by rrapier
actually, this just made my prints lean the other way. Haha
Posted: Mon Oct 09, 2017 4:22 pm
by lysaer
Hi there
I have recently been experiencing the same issue with my printer, did you ever manage to resolve this please ?
https://forum.simplify3d.com/viewtopic.php?f=8&t=8551
Thanks in advance
Posted: Wed Oct 11, 2017 8:41 am
by 3Drasle
Posted: Fri Oct 13, 2017 1:10 pm
by lysaer
Thank you, I will take a look now
