snorbitz
Can't get this to Print
Hi all..
I am a 3d printing newbie but have had some good results so far. This print is my first that requires Supports .
For Some reason S3D wont auto place the supports and when i manually place them i end up printing a stringy mess.....
Some tips or Guidance would be appreciated.
3d Printer is a Qidi Tech 1
Material is PLA
Full Model is here : http://www.thingiverse.com/thing:1615753
I have successfully printed the Outer Spheres and Button, i just cant get these internals done....
Inner_Shell_Bottom_1.75mm.stl
(2.07 MiB) Downloaded 174 times
Re: Can't get this to Print
add a factory file if you want help. otherwise no one can see your settings
snorbitz
Thanks for the heads up, I am actually going to Flip it around ( a bit counter intuitive) to see how that goes.... IF that fails i will post the Factory File.
Couple of hours before i Get home from work so it may be tomorrow before the result is known...
snorbitz
Not looking too good again. Looks like it is trying to print supports in Mid Air.
Factory File attached
Inner_Shell_Bottom_1.75mm.factory
(878.05 KiB) Downloaded 146 times
Funny enough, I just watched this video about adding S3D supports for this exact model!
https://www.youtube.com/watch?v=wPD4YL6yHX0
Heutinck
in order for the automatic supports to generate when using manual supports. you have to hit the generate automatic supports before adding the manual ones. once you press ok SD3 will not generate any other supports.
snorbitz
Great Video... Makes things crystal clear....
Thanks
