Cooling - Fan Speed Percentage?
Posted: Tue Aug 16, 2016 2:08 pm
by Innovatorator
I have a question about the fan speed.
It doesn't max out at 100%, you can set pretty much any number... so if you set it to 300 are you overdriving the fan by 3x?
I guess what is confusing me is the fact that 100% is not max?
Re: Cooling - Fan Speed Percentage?
Posted: Wed Aug 17, 2016 9:42 am
When you enter a fan speed in the "Fan speed" box, it is limited to 100%. So I'm guessing you are double-clicking on the setpoint text in the left-side list to edit it. You can enter anything you want there. You could even enter "abc" if you wanted, but obviously, you still want to stay within 0-100%.
Posted: Wed Aug 17, 2016 4:18 pm
by Innovatorator
I have a MAKEiT Pro which uses PWM for the fan, with settings from 0-255.
So does a value of 100 fan speed = 255 (max), or is it only 100 out of 255 (like 40%-ish)?
Posted: Thu Aug 18, 2016 6:21 am
It doesn't matter what firmware or printer you have. You always enter a percentage from 0-100%. Basically, if the "fan speed" input doesn't allow the value you want to type into the list, then you shouldn't be putting it there.
Posted: Thu Aug 18, 2016 10:45 am
by Innovatorator
If things such as "Support Infill Percentage" only let you put in values of 0-100, then shouldn't other things that are 0-100 percentages work the same way?
I can't put "abc" into "Outline Overlap" because it is a percentage, but I can put it into Fan Speed which is also a percentage?
