First Layer Speed Doesn't Track Setting [updated]
Posted: Thu Aug 18, 2016 11:07 am
by cssmythe3
The First Layer Speed adjustment on the Layer tab isn't working as advertised.
In the attached file, I have the default printing speed set to 2500 mm/min, and the First Layer Speed set to only 1%.
When you preview the G-Code, the SECOND layer prints at 2500 mm/min, but the first layer is shown to print around 1800 mm/min when it should be 25mm/min.
More importantly, when I run the code, the first layer prints at 1800 mm/min.
Is there some 'minimum printing speed parameter' that I don't know about?
-Chuck
Flailing in NYC
PS - I actually ATTACHED the file.
Re: First Layer Speed Doesn't Track Setting [updated]
Posted: Thu Aug 18, 2016 2:21 pm
by dorsai3d
For whatever reason, the cooling maximum slowdown defines the minimum speed that any override will slow down to. So if you lower your cooling speed override to 1% and it will slow down.
Posted: Thu Aug 18, 2016 2:26 pm
by cssmythe3
dorsai3d wrote:For whatever reason, the cooling maximum slowdown defines the minimum speed that any override will slow down to. So if you lower your cooling speed override to 1% and it will slow down.
Really? That is super weird. Well I just went to COOLING > SPEED OVERIDES > ALLOW SPEED REDUCTIONS DOWN TO and changed it to 1% and it totally worked. You are a genius.
Posted: Thu Aug 18, 2016 2:38 pm
by dorsai3d
I spent a while banging my head against a wall figuring that one out. No idea why it works that way, it seems like it's probably an overzealously applied programmatic limit.
Posted: Thu Aug 18, 2016 3:30 pm
Posted: Thu Aug 18, 2016 4:39 pm
by dorsai3d
Doug, I figure it's a change to make it very obvious whether or not the change is having any effect, rather than actually wanting to take 85 hours to print the first layer. I do similar things sometimes when trying to figure out how some setting interacts with other things.
Posted: Thu Aug 18, 2016 5:50 pm
That's okay.....just checking, and ensuring its noted that the figure you stated was not a real value.
I can just imagine someone reading the thread and thinking that a value of 1% is a sensible value...and they try it and then complain about their nozzle freezing on the first layer!!
