Another blob problem! Arrrggg.
Posted: Thu Aug 18, 2016 7:19 pm
by wirlybird
I just printed this 20mm cube. It is pretty good but it has a consistent blobbing on the corners, saw-tooth look. It is the same on all four sides and appears to be every few layers.
Mostly default settings for my printer (QIDI).
Material is PLA.
temp 190.
Re: Another blob problem! Arrrggg.
Posted: Thu Aug 18, 2016 7:30 pm
This is most likely the same issue as your other thread. Sort that one....and this will probably be sorted as well!
Posted: Thu Aug 18, 2016 7:44 pm
by wirlybird
Factory File
Posted: Fri Jan 27, 2017 1:33 am
by Blue73
Hi wirlybird,
Apologies for resurrecting an old thread, can I ask how you resolved this issue? I'm having the same problem.
Thanks.
Posted: Mon Jan 30, 2017 7:42 am
by wirlybird
It really isn't resolved just a band-aid. I set the start points to the specific setting and it helps - sometimes! Sometimes add negative restart to cut down on the blobs at the start point but that has a trade off. It can affect small/fine detail parts of a print.
Posted: Mon Jan 30, 2017 6:04 pm
I may be wrong.....but this issue looks exactly like the issue in the photo in this thread:
viewtopic.php?f=9&t=6795
Your blobs look like someone else's zigzags!
Posted: Tue Jan 31, 2017 7:19 am
by wirlybird
You got it! I saw a notice for a reply to this old post of mine and then saw his post!
This issue is a real annoyance with S3D but I have tried to live with it. Some issues like this seem at least on the surface (pun optional) to be fixable in the software but don't appear to get addressed.
