Problem with Simplify3d
Posted: Tue Aug 23, 2016 5:02 pm
by mattwoods86
I'm having issues using Simplify3d. Sometimes I will have gaps in the item that will be printed. I have attached two pictures, one of the item and one of the item that is ready to be printed. You can see the huge gaps in the print. I have the same issue, but with smaller gaps in other prints. This is ruining my printing experience!
Re: Problem with Simplify3d
Posted: Wed Aug 24, 2016 8:26 am
It would help if you posted the factory file for the build. That should make it easy to see what is wrong.
Posted: Wed Aug 24, 2016 8:52 am
by dorsai3d
Factory file would be helpful, but I'd wager that your model isn't watertight. This comes up a lot, because there's no automated warning and STL is a graphics format that enforces nothing.
search.php?keywords=mesh+error
Posted: Wed Aug 24, 2016 5:37 pm
by mattwoods86
I've attached the FF. How do you make it watertight? I have numerous other parts with the same problem!
Thanks All!
Underarm Left 1A Factory File.factory
(2.49 MiB) Downloaded 339 times
Posted: Thu Aug 25, 2016 9:57 am
by dorsai3d
STLs nee to represent solid parts, so you can't have a ton of open faces or surfaces. The part you posted looks like it was just hacked out of a larger model, so it has a ton of open faces. You can try automated repair like netfabb (https://netfabb.azurewebsites.net/), it might be able to figure out what you're getting at, but the best approach is to close the surfaces properly.
Posted: Thu Aug 25, 2016 11:37 am
Running the shape through the service WILL resolve the problems. I've tried it!
And I also suggest you note the advice I gave on this thread re supports: viewtopic.php?f=9&t=5866
