Scripts and multiple processes
Posted: Wed Aug 24, 2016 10:24 pm
I am currently using 6 extruders in simplify. And to control the print i have set one process per extruder. Depending on what i need to print i will select one or several processes.
In setting up these processes I've been careful to keep the scripts the same across all the the processes. i am not sure this is the right way. I usually use postprocessing, start gcode and tool change. So, the question is:
which process commands the use of scripts? is it always process 1? if it is process one, what happens if its not used on the print (only use process 2-4)?
Or does it combine all the scripts, say for start of tool change, and all of the from all the processes are combined somehow?
This whole thing was pretty straight forward with one extruder but multiple it is confusing with the lack of information on the software.
thanks
thanks
